Go to Post It does it automagically. - David Kelly [more]
Unread 30-01-2007, 19:06
bos1ex bos1ex is offline
bos1ex is an unknown quantity at this point
easy c default program?
Hi,
I know there is default program for text based compilers, but I was unable to find default code (the one that is on the board) for easy c pro. Is there a such thing?
Thanks,
bos1ex
Unread 30-01-2007, 19:25
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: easy c default program?
Go to build and download and it should be there. I wouldn'tt do that though because easyc is so simple i rather customized the programming to fit the robot than to customize the robot to fit the programming.
Just my $0.02
Unread 30-01-2007, 19:32
The problem is, I know only, xhtml, css and basics of PHP- there is only few weeks left so there is no way I can learn C within couple weeks.
In Easy C? I am not sure what you are referring to.
Thanks,
Unread 30-01-2007, 19:34
GMAdan's Avatar
Build and download is on the top bar. Also the lessons that come with the program are very good i just learned how to use the program a few days ago from those. And i just finished the driving and arm code today and i going to get ready for the auto-mode.
Unread 30-01-2007, 20:38
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Go through the tutorial in the help file when you get done you should be a programming wizard .
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 30-01-2007, 20:42
so you guys are saying that once i open the program, the screen i see has pre-made program ready to go just like the way it is on the board right now? if so, is easy c made only for this competition?
Unread 30-01-2007, 20:51
GMAdan's Avatar
It's not only for this compition but it is geared towards it
also i think we got the easyC for FRC verison.
Unread 30-01-2007, 21:50
GMAdan, thanks for the quick answer.
I was also wondering if there is description on how exactly the default code is set. That is, what is the current configuration of it if we were connect joistics and run it? (assuming every cable would be connected to right port/pin)
Unread 30-01-2007, 22:06
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
easyC does not have a default program. The default code is just a .hex of the code loaded in the controller when it is shipped. The idea of easyC is anyone should be able to make the equivalent of default code in about 3 minutes.
It really doesn't get any easier. For instance to make a robot with tank drive move. You drag in a while loop put a 1 in the box. while(1) and then drag in 2 or 4 motor tank block in. You tell easyC where you want to plug in your PWM ports and thats it done!
Take a few minutes to go through the tutorial and you will learn very quickly how to make your robot do its thing.
Unread 30-01-2007, 22:12
GMAdan's Avatar
If i understand your question correctly you are asking what pwm / relay relates to the joy stick buttons and axis. For this you can go to this link on the ifi website. http://www.ifirobotics.com/docs/lega...e-2004-1-7.pdf
though i still would recommend you writing your own easyc code for your robot. if need help with that pm me.
Default Code to Easy C bcharbonneau Programming 3 14-06-2011 01:31
Downloading the DEfault program gjibben Programming 1 11-02-2004 21:20
default program nick_champ_2 Programming 2 06-02-2003 13:11
default program Billyp04 Programming 26 14-01-2003 15:48
1999 Default Program... archiver 1999 4 23-06-2002 23:09
