Go to Post ...too much to do... ...too little time... - Joe Johnson [more]
Unread 31-01-2007, 11:26
SoD SoD is offline
FRC #2230
SoD is an unknown quantity at this point
How to calculate arm angles?
Hello,
I want to know for how long should the motor work in order for the arm to move one degree.
Unread 31-01-2007, 11:48
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: How to calculate arm angles?
You could use a protractor to measure the angle change from your initial starting position to where you want it. Then if you have a potentiometer or encoder on the arm, you could also measure the change in the potentiometer reading or the number of encoder "clicks" That would map angle change to a sensor feedback
Eric
Don't PANIC!
S. P. A. M.
Unread 31-01-2007, 11:55
SoD SoD is offline
FRC #2230
We have a GTS, but we want to check this way - how can i check the time in which the arm move for one degree using the program running time
Unread 31-01-2007, 12:43
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Due to varying motor speed/power at the different battery levels, different loop execution times because of calculations and various little things like that you can't do it the way you wish.
http://www.mikesorrenti.com/
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Depending on the gear that the GTS is reading you should know the resolution of the movement ie. How many teeth per 1 rev. Knowing that data if you want the time for 1 degree figure out how many pulses form the sensor you get over 1 degree then use a clock to figure out the time it takes for "x" amount of pulses.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 31-01-2007, 14:17
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
A standard variable resistor, also known as a "pot" or potentiometer can be attached to the axle upon which your arm rotates.
The output of the pot can then be hooked up to an analog input on the RC to show... well... not exactly what ANGLE your arm is at, but certainly how far your resistor has been turned, which is essentially the same thing.
While there are custom pots built specifically for this purpose that offer greater precision and durability, we used a standard, everyday one that you can find at any electronics store on our 2005 robot and it worked (and continues to work) like a charm.
Just make sure that you get a "linear taper" instead of an "audio" or "logarithmic" taper. That way when the pot is turned all the way in one direction your analog input will read "0" (or pretty close to it), halfway around it will read 512, and at the other end of the rotation it will read 1024.
Then you can just tell your motors to turn until the analog input from the pot reaches a certain value that corresponds to the angle you are seeking.
In fact, with a bit of programming you can essentially turn your arm into one big servo motor.
Jason
Pressure Angles Smrtman5 Technical Discussion 6 07-11-2005 20:53
How to calculate planetary gear ratios? sanddrag Technical Discussion 2 27-02-2005 11:55
How long is your arm? Alex Cormier General Forum 27 19-02-2005 23:34
How do you Calculate Belt Length? Gabriel Technical Discussion 7 08-11-2004 14:54
How to find the moment of an arm Matthew_H Technical Discussion 7 26-10-2004 12:20
