Go to Post We have to have a water-based game discussion each year, because every time I try to start up a "jello-based game" thread no one takes me seriously... - dlavery [more]
Unread 31-01-2007, 18:59
nyu500 nyu500 is offline
FRC #2207
nyu500 is on a distinguished road
Exclamation What to do about wheel traction???
The WBL Beartronics team recently purchased the tread for the tires that were advertised through FIRST, and can be purchased through IFI Robotics. We had plans to simply rivet the tread onto the stock wheels, but it seems to be an inch short. Does anyone know how to solve this dilemma? Also, if no other solution can be solved, does anyone know how to remove the original treading from the KOP wheels? They wheels tread was molded onto a plastic T attached to the base, so if we were to cut all of the tread off, it would cut off that T as well. Any help would be greatly appreciated.
Unread 31-01-2007, 19:03
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
Team Role: Leadership
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Re: What to do about wheel traction???
thats odd we never had that problem, but measure it and contact ifi if it is the wrong size. if it turns out to be the right size, make sure the tread wraps around the wheel and is not too far off in any stop.
Unread 31-01-2007, 19:23
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The problem is that you bought tread that was cut for different wheels then you tried to apply it to.
The 6" IFI Traction wheels have a 5.6638" OD, while the 6" AndyMark FIRST Wheels have a 6" OD. Thus, the circumference of the AndyMark wheel is about 1" longer then the IFI wheel.
I can think of a bunch of different solutions:
Cut/grind the rubber from the AndyMark FIRST wheel to 5.6638" OD
Buy the 6" IFI Traction wheel and use the tread you already purchased
Buy the tread material directly from McMaster Carr and cut to size.
Buy either the AndyMark traction wheels or performance wheels
Unread 31-01-2007, 20:08
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
I don't think trying to fit IFI tread on the AndyMark KOP wheels is worth the effort, not to mention you might ruin a set of perfectly good wheels in the process. Go for the IFI traction wheels, and keep the AndyMark wheels as a spare.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 31-01-2007, 19:11
Billfred's Avatar
Billfred Billfred is offline
Now this is something that we on 1618 have some expertise with. Consider:
http://www.chiefdelphi.com/media/photos/26437
http://www.chiefdelphi.com/media/photos/26439
We cut the tread off on a bandsaw with no real problems to the wheels. Just cut carefully, and remember that the area of the cut is going to be H-O-T HOT. (I'm finally just about recovered from the burn. It was not enjoyable at all.)
From there, drill holes and rivet.
pic: Custom VEX Traction Wheel Rim Chuck Glick Extra Discussion 20 03-10-2006 17:34
Question About 4-Wheel Drive Pat McCarthy Technical Discussion 19 26-06-2005 23:38
Reducing wheel traction dude__hi General Forum 18 29-03-2004 18:43
WHEEL TRACTION--PLEASE RESPOND archiver 2001 10 24-06-2002 00:36
WHEEL TRACTION--PLEASE RESPOND archiver 2001 7 24-06-2002 00:36
