Go to Post There is no rule that specifically states that you must obey the law of physics during the competition. This may be an oversight. - bmather [more]
Unread 31-01-2007, 21:35
comwiz7's Avatar
comwiz7 comwiz7 is offline
AKA: Joey
FRC #1323 (Madtown Robotics 1323)
comwiz7 will become famous soon enoughcomwiz7 will become famous soon enough
Send a message via MSN to comwiz7
Radio problem
We have been running our robot with a Tether and hooked up our radios today and they bot stay on standby is there something we need to do to make one transmit and one receive
Unread 31-01-2007, 22:48
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: Radio problem
Make sure you have the one labeled robot controller on the robot and the one labeled operator on the operator board.
Unread 31-01-2007, 23:05
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Re: Radio problem
Do not change your team number from the default until you have it tethered. And if your changing the channel your team number needs to be above 2048 if i remember right. Sometimes i have found you have to dis-connect the robot radio-modem while your tethered and then reconnect it, and it majically starts working.
But i would keep it on channel 40 and just change the team number.
Also check for bad cables.
Other than that i am not sure.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
2007 Radio link reliability problem Dave K. Control System 12 02-02-2007 22:26
Radio Problem on FRC TuaMater Control System 4 26-01-2006 07:32
Radio Modems ChuckDickerson Control System 4 09-11-2005 16:31
radio problem Anton Control System 1 19-02-2005 12:22
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
