pic: lego inverted pendulum
Re: pic: lego inverted pendulum
yes i saw the legway but my goal was to do the same sort of thing with the regular light sensor and with out NQC, legos, the hard thing is that rcx brick programming only let you use .001 increments were as i wanted .00001
plus i want a 11 year old to do it for the rmsc summer camps ![]() |
colin sweet
does it work w/o that handle?... with a load? |
I had tried doing something similar with RCX v1.5, but I could never get the light sensor to be accurate enough.
Looks great and if you can make it work good for you. |
did you try it on a surface with some luster and in the dark
I tried it on anything I could. It has been a while since I tried it, but I didn't think I could get more than ~2 inch accuracy(in dark room. on a piece of wood with black contact paper covering it).
If I can get my RCX out of the closet I'll probably test the light sensor again. |
| Inverted color mind tricks! | thegathering | Chit-Chat | 19 | 31-08-2006 18:05 |
| pic: Lego Launcher | Ian Curtis | Extra Discussion | 11 | 17-06-2006 10:26 |
| LEGO Unveils new LEGO Mindstorms NXT Robotics Toolset | Danny Diaz | Lego Mindstorm Discussion | 21 | 25-05-2006 19:56 |
| Camera Picture is Inverted | winners | Programming | 2 | 27-01-2006 20:09 |
| IR signals inverted | Atheist | Electrical | 10 | 08-02-2004 16:27 |
