Go to Post Of course I'm not an admin, so this opinion is worth about as much as a disco record or AOL Free Trail CD. - PayneTrain [more]
Unread 01-02-2007, 00:38
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Programming our Arm
Our arm is controlled by a motor with a sprocket at the base of a long beam. Obviously there is much torque on this system, and when the motor moves slightly, the arm jerks a lot. Understandable. How can we make the arm motion more fluid persay--if we just twitch the joystick right now the arm makes a wide movement.
Second: If the motor stops the arm immedietly jerks back down. Suppose we wanted to keep the arm in a set position--how would we do that? So if we let go of the joystick, the arm would stay in the same position that it was in.
Make our own VEX programming cable? Chris_Elston Programming 5 18-04-2006 00:02
pic: Who needs teasers... here's our arm! [CRUSH: 1011] CD47-Bot Robot Showcase 11 09-02-2004 22:32
Arm Rotation (1 Button Programming!!) Joelster Technical Discussion 1 14-02-2002 13:15
Arm Turning (programming) Joelster Programming 4 13-02-2002 21:35
