Go to Post Note to self: Go to IRI sometime. - [more]
Unread 01-02-2007, 09:27
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
reserving air
Is it illegal to use take a storage tank and reserve it using one way connectors?? Basically being able to charge the whole system by using the pump, but letting only one piston run off a storage tank.
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Unread 01-02-2007, 09:44
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Rookie Year: 2000
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: reserving air
Yes, as long as all of the components meet the rest of the rules. Each tank will require a separate 125 psi gauge (high side), reducer, and 60 psi gauge (low side).
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 01-02-2007, 14:28
Pro E King
#0157 (AZTECHS 157)
Re: reserving air
Is that a yes, they are illegal to use, or a yes, your can as long as your follow the rules?
157 The Aztechs
Luck of the Irish
Unread 01-02-2007, 15:33
Dantvman27's Avatar
Dantvman27 Dantvman27 is offline
Mentor - Awards/Scouting
AKA: Dan
FRC #3467 (The Windham Windup)
Dantvman27 is just really niceDantvman27 is just really niceDantvman27 is just really niceDantvman27 is just really nice
Send a message via AIM to Dantvman27
Re: reserving air
of course you can hold air
Help me live out my dream:
http://igg.me/at/CZTheatre0/x/5956991
Out of retirement and with a new team!
Formerly of FRC241 now mentor with FRC3467
Teaches strategy, presentation skills, awards management, and FIRST history
Holder of a BA in Theatre
FLL Student: 2003-2005 FRC Student: 2005-2009 FRC Mentor: 2010-2011 (241) 2014-? (3467)
RIP FRC Team 241
2010 UTC Regional Imagery Award Winners
2014 UNH District Chairman's Award
2014 Northeastern District Engineering Inspiration Award
ASTROMAN!
www.nhtechfest.org
twitter.com/nhtechfest
Unread 01-02-2007, 16:19
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: reserving air
Yes you can do this. However for each tank that is not within 1 system (meaning if you have them set so that the compressor doesn't fill them in series or parallel) then you need to have a PSI gauge on the tank that is not within the system.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 01-02-2007, 16:48
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: reserving air
If the devices you intend to use are on the allowable list of pnuematic parts and you can fulfill the other aspects of robot rules (i.e. releasing the pressure through the supplied valve) and if your part can be followed through the flowchart, then it is likely OK. If you are planning something different, you should post the question on the Q&A. Better safe than sorry later.
Al
WB9UVJ
www.wildstang.org
________________________
Reserving Seats for Scouting fatjoe3833 Scouting 2 01-03-2006 11:51
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Air Fares Ken Loyd General Forum 19 24-09-2004 13:40
Air Jordan matt111 Rumor Mill 21 03-02-2004 18:59
Air Tanks geo Pneumatics 8 25-03-2002 15:13
