Go to Post You know you're addicted to FIRST when...You relabled the speedometer in your parents car so that 0 is 127 - Sharkbyte [more]
Unread 01-02-2007, 15:41
Metalgod4eva Metalgod4eva is offline
None #0870
Metalgod4eva is an unknown quantity at this point
Function for O over a serial.
I am a happy computer programmer and well never played around with a robot before. Being a computer programmer I am use to the computer standard ways of doing things. I wrote this for the robot
Code:
 #include <stdio.h>
#define AMOUNT_OF_LINES 1
int reprint(void)
int i,x,r;
int farray[200],*fa;
FILE *fp;
fp = fopen("c:\\text3.txt", "r");
fa = &farray[0];
for(x=0;x<123;x++)
    *(fa+x) = (fgetc( fp ));
     printf("%s",fa+x);
fclose(fp);
int write(void)
 	  int c,x,i,y,n, *sp, string[200];
      sp = &string[0];
 	  FILE *fp;
 	  fp=fopen("c:\\text3.txt", "w");
    for(x=0;x<3;x++){
      scanf("%s",sp+x); }
      for(n=0;n<3;n++) {
      fprintf(fp,"%s",sp+n); }
      fclose(fp);
int main() {
   int x;
   write();
    reprint();
    scanf("%d",x);
    /* by metalgod4eva team 870 */
/*for loops not complete, still need to make another function */
Well as you can read its a nice file IO, I am looking to use the serial to O back to the computers hard drive and save and in looking in the source for the serial I found no O function back over its device. Maybe I just over looked it and its there or I will have to write it. If anyone has an idea or solution let me know. Also I think I might have to use fwrite instead of fprintf but no issues there. Dont complain if you do run it and find the garbage data I have not finished the fuction for the for loops yet. Thanks for your time and have a nice day!
Unread 01-02-2007, 18:35
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Function for O over a serial.
The code for the robot isnt exactly like standard C for a computer, you might want to look at the default code
www.kevin.org/frc
And read the programming ref guide from IFI
http://www.ifirobotics.com/docs/lega...2-apr-2004.pdf
Unread 01-02-2007, 20:54
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
If I understand this is what you want. Just Printf all you info like you normally would. But write a custom app that reads those values and logs them to a text file. Is that what you want?
Unread 01-02-2007, 21:31
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
Even simpler, forget a custom App, depending on the kind of data you're using a properly formatted printf(), Hyperterm and Excel are your best friend.
I had to monitor the PID response for last years robot and a bunch of numbers wasn't doing it for me, so I had a printf like this:
Code:
printf("%d,%d,%d,%d,%d",kp, ki, kd, error, output); // This is a loose guess at what it was
Then I told HyperTerm to save to a file, and let the robot run, then using Notepad++ (it handles large text files better than notepad does) I trimmed out the section I needed and imported to Excel as a CSV (Comma Separated Values) file. Then I re-saved to .xls and started graphing, thanks to Mark McLeod for that awesome tip.
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Dampening function for driving. Brad Voracek Programming 2 13-01-2007 14:18
Loop time for OperatorControl function? Debug blows... Chris_Elston Programming 10 13-02-2006 14:42
USB serial adapter for OSX? Validius Programming 1 05-01-2006 01:43
FIRST Over For WRONG 1430 russell General Forum 13 26-11-2005 16:01
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
