Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 01-02-2007, 16:32
magruderrobotic magruderrobotic is offline
FRC #1820
magruderrobotic is an unknown quantity at this point
Can we use these sprockets?
Since rule update #6 on January 26th we've been a bit confused about the legitimacy of the sprockets we obtained before the clarification was made. We bought standard #35 sprockets with a 1/2" bore and 25 teeth to match the drive shaft from the banebot gearboxes. We didn't really understand why the kit would include a sprocket with a 1 1/4" and a keyed drive shaft with a 1/2" diameter. Is the sprocket that we bought legitimate for use in the competition?
Unread 01-02-2007, 16:36
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Can we use these sprockets?
If you bought a part from somewhere that any team can buy from (Which is most likely true) then absolutely yes. If it is identical to a part you can get at a retailer any team can buy from, then yes.
Most likely this is okay, be a little more specific for clarification though; Where did you buy it?
Unread 01-02-2007, 16:40
FRC #1820
We bought our sprockets from Grainger Industrial Supply and they were not custom made. Completely standard stuff.
Unread 01-02-2007, 21:39
SPARKY1688's Avatar
SPARKY1688 SPARKY1688 is offline
AKA: Marko Rajacic
FRC #1688 (StickShift)
SPARKY1688 will become famous soon enoughSPARKY1688 will become famous soon enough
As Long its available to the other teams and it is okay with the flowchart, then the partt is legal,
so if you bought it from granger a supplier its first legal
-marko
Where can i get more sprockets aviva[x]core Kit & Additional Hardware 2 14-01-2007 01:26
where can i find these?? jazzsaxman1988 Programming 3 05-02-2005 01:24
Where can I get sprockets, drive axles, etc. SPARKY1688 Kit & Additional Hardware 1 13-01-2005 20:59
pic: Can you ID these people? CD47-Bot Extra Discussion 21 19-04-2004 19:49
Q&A Discuss: Re: Can you help me answer one or two of these questions? CD47-Bot Extra Discussion 1 08-01-2003 20:39
