what is the green light on the cam? (was: I NEED YOUR HELP!)
HI EVERYBODY!
ANSWER ME PLZ ON THESE QUESTIONS: 1)WHEN I TURN ON THE CAMERA ONLY THE GREEN LED LIGHTS WHY IS IT SO?? AND ANOTHER QUESTION I ALSO GOT THE MASSEGE "THE APPLICATION IS ClosING BECAUSE OF REPORTED ERROR" HOW I CAN FIxxx IT??? tnX FOR YOUR HELP ![]() |
Re: I NEED YOUR HELP!
The green light means that the camera has power..
What application is giving you the error? Mplab? IFILoader? |
Re: what is the green light on the cam? (was: I NEED YOUR HELP!)
The red LED comes on when the camera is tracking a target.
It will also blink to indicate data transfer, like when it is downloading a frame.
The application closing message is most likely because the application did not make (or lost) a connection with the camera. Check your serial port settings (115,200 baud, etc.) as listed in the manual, and that the application is set to use the correct PC serial port. Are you using the Java GUI or the LabView one? Last edited by petek : 02-02-2007 at 08:02. Reason: clarification |
| PROBLEM - the cmaera doesnt detect the GREEN LIGHT | razer | Programming | 4 | 30-01-2007 00:48 |
| Problems with the manual of the green target (for cmu cam) | Kawashima | Kit & Additional Hardware | 1 | 28-01-2007 13:31 |
| Help How do i assemble the green target light?? | jesusescobar | Electrical | 2 | 26-01-2007 17:32 |
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) | liad | LabView and Data Acquisition | 8 | 18-01-2006 12:20 |
