Go to Post At GLR our team only had to deal with a bunch on kids seeing snow for the first time. With all the ensuing snow fights and vainly trying to run up the giant snowy hill behind the arena. - Kevin Sevcik [more]
Unread 01-02-2007, 18:49
iwdu15 iwdu15 is offline
FRC #0811
iwdu15 is an unknown quantity at this point
adding second camera
hi, quick question for you electrical people...hopefully your the right people to ask. is there anyway to hook up a second camera to the RC? I am trying to use the camera from 2006 along with the camera from this year. is there any way i can hook this up? thanks
-iwdu15
--team 811
Unread 01-02-2007, 20:53
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: adding second camera
Use the program port on the RC to communicate to the second camera over RS232 not using TTL, get kevin watson's serial ports code to talk over that serial port.
There are a few different ways of communicating to the camera over a serial port, i suggest starting with kevin watson's documentation and then move to the two camera code posted by FIRST (as a reference on protocol format).
This will be difficult to debug, so you might consider using the user byte format which is sent to the OI. You can use the dashboard (available from IFI ) to read the user byte format.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Adding Code haywirerobotics Programming 2 18-01-2006 07:04
second camera sj31419 Programming 7 20-01-2005 18:19
Adding objects Matthew_H 3D Animation and Competition 5 12-02-2004 19:33
Adding RAM to RC archiver 2001 1 24-06-2002 00:59
Adding my Thanks archiver 2000 0 23-06-2002 22:57
