Go to Post GP isn't just a good idea, it's mathematically optimal. - Jared Russell [more]
Unread 01-02-2007, 21:40
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
AAH I'm spazzing out because I can't get our camera to do anything!!!
Sorry about the general thread title; it's meant as a joke--that's one of the questions in Kevin's FAQ.
But this one's different. I've got a bit of a puzzle here.
I use Kevin Watson's default camera code, and it works like a charm. I use my modified code, and it...doesn't. It "error 131"s over and over again.
I spliced an RS232 connector onto a PWM cable to test my TTL converter, camera, and cables in between. All of my hardware works great. I receive "CR>" and some odd character in my terminal window when connected from the TTL converter out to my com port. I get the same thing on the very end of the PWM cable I had plugged into the camera. I can talk to the camera through this port too, but only if I switch TX and RX. I'm too brain-fried to think that through; don't read too much into it because I could be wrong. The camera responds like I think it should.
My code is receiving the bytes I send it. I put a simple printf of the byte count every loop and saw it change when I sent it bytes.
Kevin's serial port diagnostics indicate that communication from and to the computer and from and to the camera are all good.
I am not getting any bytes back from the camera itself, however. My byte counter never lifts off 0.
I would post my code, but I have some confidential stuff in there--I'd have to strip it to make it neutral before I post it.
So, any ideas? Do you really need to see my code (I think you probably will ask for this, I'll post it tomorrow if you do)?
Thank you so much.
JBot
Aren't signatures a bit outdated?
Unread 02-02-2007, 16:21
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Re: AAH I'm spazzing out because I can't get our camera to do anything!!!
Figured this out myself today. The serial_ports.h by default has the TTL port set at 9600 baud; the camera expects 115200. I haven't tested with the robot yet, but I'm sure this is my problem.
Thanks, Kevin Watson's FAQ!
JBot
Unread 06-02-2007, 22:29
1594code 1594code is offline
FRC #1594
1594code is an unknown quantity at this point
Your quote from Kevin's website hit close to home! Our team really can't get the camera to do anything! It doesn't lock onto the target...
We've been using Kevin Watson's Bells and Whistles code (though I also tested the Streamlined code). We have the pan/tilt servos connected to PWM01 and PWM02. We have the power connected to another PWM output, and we have the TTL cable connected between CMUCam and RC. We see the output "searching... searching... searching..." We've read Kevin's FAQ (#3) on this symptom, but we didn't modify his camera settings or calibrate; we don't think that's the problem. We tried increasing the search delay by one, as Kevin suggests (FAQ #14). We have our camera mounted such that the lens is in the bottom half of the camera.
Does anyone have any ideas? Did you do any configuration to the camera or the code to get things working? We've learned a lot in the process of all our debugging, but we haven't gotten beyond "searching... searching... searching..."
Thanks for any suggestions you may have to offer!
Unread 06-02-2007, 23:43
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Does the camera actually search for the light, i.e. do the servos move? Or does it just print "Searching..."?
Also, does the red LED on the camera light up when you put the green target light in front of it?
Good luck,
Robinson
Unread 08-02-2007, 19:30
FRC #1594
Yes, the pan and tilt servoes have worked all along-- I forgot to mention that in my earlier post.
The camera's red light blinks constantly as the camera searches... but it does seem to be on when the green lightbox is in the camera's field of view.
New development today: the camera reported pan angle, tilt angle, blob size, confidence for the instant that the light box is in the camera's field of view. Then, it changes direction and keeps searching. This sounds like Kevin's FAQ #9, but our camera power switch is on the bottom. I tried switching the signs on the PAN_ROTATION_SIGN_DEFAULT and the TILT_ROTATION_SIGN_DEFAULT. I also slowed increased SEARCH_DELAY_DEFAULT by one.
If anyone has any other suggestions, I'd be grateful to have them!
Unread 08-02-2007, 20:12
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
I've seen this wacky behavior when the light isn't getting enough power; the camera will find the light and start to track, but after a second or so, the camera will start a new search. Use a freshly charged robot battery to power the light (not some ~12 volt wall-wart left over from a toy your little brother destroyed long ago). Also consider modifying the search algorithm to better meet your needs.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 09-02-2007, 22:58
FRC #1594
Hey! We're tracking now! Thanks, gnirts and Kevin!
Wiring the green light box to a freshly charged 12 Volt battery definitely helped!
In the end, I kept TILT_ROTATION_SIGN_DEFAULT and PAN_ROTATION_SIGN_DEFAULT the same, and I kept the SEARCH_DELAY_DEFAULT.
It looks like the red LED blinks even when the green target is not in view, but tracking works...
Unread 10-02-2007, 16:22
Ianuser Ianuser is offline
FRC #0570
Ianuser is an unknown quantity at this point
Hi, I'm having a problem that would occur earlier than the problem you just had. I can't get the servos on my camera to function at all. They moved for a second the first time I plugged it into the RC and a green light (i think it was green) came on. Then I downloaded the most recent version of my code and forever more the camera would not turn on. My servos are mapped to PAN_SERVO pwm06 and TILT_SERVO pwm07, and in the default routine() I commented out the joystick mappings for those servos. I also commented those servos out in the User_Initialization() when the pwm's are all set to 127. So, Why is my camera not working? (I read somwhere that it has to be mounted upside down? With the camera and the power button on the bottom of the tilt? That shouldn't affect this though.)
Unread 10-02-2007, 19:14
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
-Kevin
Not to threadjack, but just out of curiosity, will the power supplied from a digital/analog input (supposed to be 5 volts) be sufficient to reliably power the camera? I have been using it, and maybe 1 out of 20 power-ups the initialization fails and I have to power-cycle, but you say 12 volts; I can have our electrical team wire another circuit breaker and run 12v out to the camera if you think it would be better.
Just wanted someone else's opinion...
JBot
Unread 10-02-2007, 19:27
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
JBot
He is talking about using 12V to power the target light, not the camera. You should use 7.2V to power the camera, which you can pull from a PWM port. I wrote about this issue at length here.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 10-02-2007, 22:01
nzj1's Avatar
nzj1 nzj1 is offline
#0547 (F.E.A.R.)
nzj1 is an unknown quantity at this point
We're having problems with our camera also. The story is that the camera worked, then it didn't. While the robot was being driven for practice it started working again and worked well. To our dismay, it stoped working again. We (not me, I'm not our tech person) have done all the troubleshooting that we can think of. I'm thinking it might be some kind of firmware issue although I'm told that it probably isn't. Oh... By the way... this is our third camera for the third year running that has, to the best of our knowledge, been hosed. Luckly We've not needed it untill this year, depending on how you judge luck. We're in desperate need of help and would be eternally grateful.
2001 VCU Rookie All Star
2001 National Rookie All Star
2002 KSC Delphi Driving Tomorrows Technolgy
2002 Newton Quarter Finalist
2003 St. Louis GM Industrial Design
2003 Archimedes Finalist (47, 201, 547)
2004 St. Louis Chairman's Award
2005 Gret Lakes Judges Award
2006 St. Louis Winner (547, 71, 537)
Unread 10-02-2007, 22:21
FRC #1594
The servos should drive the camera frame to scan its field of view even when the green light is not on. Hm... Does your Process_Data_from_Master() function still call Camera_Handler() and Servo_Track()?
Also, do you have your joysticks plugged in as you test the camera? The default routine makes calls to the joysticks, even if you're not planning to drive while testing the camera.
I don't think you need to comment out any pwm initialization code in User_Initialization(), as the Main() function only calls User_Initialization() once.
Unread 11-02-2007, 00:29
Guru's Avatar
Guru Guru is offline
Executive Programmer
FRC #0912 (Iron Lyons)
Guru is an unknown quantity at this point
Hey, I prefer banging my head on the wall to spazzing out, and I've been doing it all today... and yesterday... and the day before...
I'm not sure why, but the Kevin's camera project wont compile, error in streamlined version: plcxxx.h not found even though it should be auto included, and in bells version: stdio.h not found even though it should be auto included). The pre-compiled hex file works perfectly enough, so this might be a problem with our compiler... With only one week left it gets kind of frustrating, but the answer is here somewhere... somewhere...
\/\__Under Construction__/\/
Unread 11-02-2007, 13:26
FRC #2429
Go to Projects -> Build Options... -> Project -> General tab. Make sure the last three paths are correct. Your paths may be different, but on my laptop, the include path is c:\mcc18\h, library is c:\mcc18\lib, and linker scripts is c:\mcc18\lkr.
-Kevin
Kevin Watson
http://kevin.org
  #15   Spotlight this post!
Unread 12-02-2007, 11:17
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
We were perplexed a couple of times when our camera stopped, even though its lights were still on. Replacing the backup battery with a fresh one did the trick for us.
Jason
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Camera fails to output anything on serial lines steven114 Electrical 10 18-01-2005 16:12
Why can't we get along? Sean_330 General Forum 23 19-03-2003 21:38
i'm in the charleston area, and i'm looking to help out a team near here... dickymon General Forum 2 05-08-2002 16:40
Can't WE all just get along? archiver 2000 0 23-06-2002 22:29
