Go to Post I'm sure I'm not the only one that feels like a blind man in a room full of sharp objects when it comes to programing. - Protronie [more]
Unread 02-02-2007, 04:44
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Rookie Year: 2007
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Understanding blob size
Code:
case RECEIVING_T_PACKET:
			if(packet_buffer_index < sizeof(T_Packet_Data_Type)) // still building the packet?
				// move packet character to our buffer
				packet_buffer[packet_buffer_index] = byte;
				packet_buffer_index++;
			if(packet_buffer_index == sizeof(T_Packet_Data_Type)) // complete packet?
				T_Packet_Data.mx = packet_buffer[0];
				T_Packet_Data.my = packet_buffer[1];
				T_Packet_Data.x1 = packet_buffer[2];
				T_Packet_Data.y1 = packet_buffer[3];
				T_Packet_Data.x2 = packet_buffer[4];
				T_Packet_Data.y2 = packet_buffer[5];
				T_Packet_Data.pixels = packet_buffer[6];
				T_Packet_Data.confidence = packet_buffer[7];
				camera_t_packets++;
				state = UNSYNCHRONIZED; // we're done; go back to the unsynchronized state
This is one of the switch-cases of the Camera_State_Machine function.
I'd like to understand how it determains the blob size given in the terminal so I can also use it in autonomous mode(T_Packet_Data.pixels = packet_buffer[6];, what happens in that code line).
Unread 02-02-2007, 11:49
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Understanding blob size
The blob size (.pixels) is calculated by the camera and sent as part of the t-packet.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 02-02-2007, 17:26
AKA: Nir Levanon
Rookie Year: 2007
Where's the calculation area?(not sure if it's important for me, especialy when it's after midnight here, but I'd like to know anyway)
Unread 02-02-2007, 18:05
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It's in the firmware of the camera. I think all it does is count the number of adjacent pixels which match the specified color.
I'm curious to know why you're focusing on this, and how you expect to use the information you're asking for.
Unread 03-02-2007, 10:55
AKA: Nir Levanon
Rookie Year: 2007
Well, I'm hoping to find a certain blob size range(as I saw in the CMU demo clip, the blob size is not soo stable, so I want to find that limit of the instabilaty)when in a certain range so I can create a certain (I think that's the word -) algorithim that will check if the size of the blob in certain distance from the light(that is diffrenet from the distance of the defined blob size) equals the same size of the defined blob(meaning, when both distances come range 0 with the light, the light will be the same size). That way I will be able to distinguish between 1 light in view in a close distance from the camera and 2 lights in view in a far range from the camera.
Unread 03-02-2007, 18:37
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The blob size is calculated as:
"the number of pixels (of green in our case) in the tracked region, scaled and capped at 255: (pixels+4)/8"
You'll find this information in the CMUCam2 User's Guide where it gives a brief description of the T packet (p.60)
Minimum blob size royalfire Programming 0 18-01-2007 16:56
Memorandum of Understanding (MOU) KathieK Team Organization 0 03-01-2007 12:43
Blob Size d.courtney Programming 7 29-01-2006 20:48
Understanding engineers Katie Reynolds Chit-Chat 0 27-02-2004 18:04
Help with understanding Fuse panel Blue_Midnight Electrical 3 10-02-2004 23:12
