Go to Post Success is the indescribable feeling you get when you see something you worked so hard on in front of thousands of people. - SlamminSammy [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 02-02-2007, 19:35
VideoMan053's Avatar
VideoMan053 VideoMan053 is offline
Computer Freak
AKA: Dan J.
FRC #0063 (Red Barons)
VideoMan053 is an unknown quantity at this point
Send a message via AIM to VideoMan053
Question default button maps anyone?
I have been searching the forum like crazy, but no luck...
According the the User Manual that came with the USB Chicklet, there are certain buttons, namely buttons 1, 2, 3, and 4 that will be matched to the port trig, top, aux1, and aux2 buttons.
I am using an xbox 360 controller and will be using mode 2, for four analog supports, but I am trying to figure out, which buttons are assigned to buttons 1,2,3,4 by default when you first plug the controller into the chicklet.
The User Manual seems to hint that these buttons would be A,B,X, and Y respectively, but can someone tell me definitively?
Hint to what I'm trying to get at...
Is this true?
XBox - Chicklet (Mode 2) - OI Buttons
"A" ... Button 1 .......... pX_sw_trig
"B" ... Button 2 .......... pX_sw_top
"X" ... Button 3 .......... pX_sw_aux1
"Y" ... Button 4 .......... pX_sw_aux2
GET OVER IT! ~ not the most useful words in competitions, but some of the most useful in life!
My Jobs: Programming
Unread 02-02-2007, 21:38
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: default button maps anyone?
Is this true?
The default mode for the Chicklet is mode 1. This mode is the only mode where the buttons are set to a default value for you. If you want to use mode 2 then you must calibrate the chicklet to mode 2. During calibration the user can select which buttons are assigned where. The first four buttons pressed will be assigned to in the order pressed as follows:
pX_sw_trig
pX_sw_top
pX_sw_aux1
pX_sw_aux2
You cannot simply select the mode and then end calibration mode. You must complete the calibration procedure in its entirety.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 05-01-2009, 18:31
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
Re: Problems involved in sentences
There's an easy way to figure out button numbers and axes on the 360 controller. Plug it in to a computer and go to the test screen that lets you make sure it's correctly calibrated for usage, and click each button to be sure (and don't forget the thumbstick and D-pad buttons)
The triggers are treated as a separate axis, fyi.
Maps for FLL and not just FRC? KathieK FIRST Lego League 5 22-11-2004 12:02
IRI maps, agenda, etc.. tminard Off-Season Events 10 11-07-2003 23:26
Anyone think that anyone will get near 1000pts @ Nat's archiver 2001 22 24-06-2002 02:50
Point, polygons, texture maps - lend me your pixels! Robby O 3D Animation and Competition 6 16-04-2002 21:02
Button Bar Adrian Wong CD Forum Support 8 04-06-2001 20:27
