Go to Post I personally think mentors should sit behind two-way mirrors and hold a kill switch for all power tools. ;) - SenorZ [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 02-02-2007, 21:08
Elpants's Avatar
Elpants Elpants is offline
FRC #1566 (Ammoknights)
Elpants is on a distinguished road
Send a message via MSN to Elpants
Problem with Inventor 11 Dynamic Sim Tutorial?
So, since we got most of our major parts for our bot designed I thought I might work a little with the simulation of inventor since I had not had the chance to for the past 2 years that I have been in first.
I have used Inventor tutorials since I first started using it, in fact its been the only teacher I have had in using it. So I like to say I was self educated in Autodesk .
Anyway in the Dynamic Simulation tutorial I get to the point that I am creating joints on the shaft thingy (Dont have the exact names off the top of my head atm.) then animating it for 10 seconds. The Gate itself swings fine but the shaft and the connection for the gate to the shaft just flies off into space because its not jointed to the gate itself.
I have tried fixing this and done the tutorial several times up to this point and get the same result of it flying off into space for the duration of the simulation.
Anyone else have/had this problem and know a fix for it?
Any help greatly appreciated.
Urgent problem, probably with Inventor 11 install. Eric Scheuing Inventor 4 03-01-2007 07:43
Inventor Problem w/ saving Pat Roche Inventor 2 14-02-2005 21:36
Dynamic Linking with PHP plutonium83 Website Design/Showcase 6 12-01-2005 19:41
HELP! Problem with General Dimension in Inventor 5. sanddrag Inventor 12 21-09-2003 21:46
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
