Go to Post Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads: "Be sure to drink your Ovaltine" - Jill_ls101 [more]
Unread 02-02-2007, 21:33
jsmith234 jsmith234 is offline
Jared Smith
FRC #0234 (Cyberblue)
Team Role: Electrical
jsmith234 is an unknown quantity at this point
Send a message via AIM to jsmith234
New Power Distribution
[b]What is your opinion as to the new power distribution pieces compared to previous methods of wiring?
Cyber Blue - Team 234
2007 BMR Chairmans Awards & Regional Champions
Entrepreneurship Award, Website Award
2007 Long Island Regional Champions,
Industrial Design Award
Unread 02-02-2007, 21:57
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Re: New Power Distribution
we DISLIKE IT WITH A PASSION. we'd always buy one large breaker box that held the 40s and 30s (or maybe 20s?) on one convenient panel. it was great because it was compact, clean, and LIGHT. this year we're bummed because we have to use the KOP stuff - especially that gold plated 40 amp box. it's such a waste of weight.
I think those power distributors are nifty but they take up too much space. it's a cool system and I like the design, but it's just another thing that's replacing something that worked fine.
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
Unread 02-02-2007, 22:12
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Agreed. I ranted about this at the beginning of the build season. Look at my picture of my board because of it.
Jacob
Unread 03-02-2007, 01:04
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
i believe that you can improve that significantly with a little bit more time even though you are upset by the work the power distro block has caused you. I can assure you that even though it is a minor inconvenience teams will come up with a clean, safe, and effective way to work around this (go find a picture of the block in 2004, that was fun to work with). I hope that you do not use the block as a scapegoat, but rather as a challenge that needs to be met.
Unread 03-02-2007, 01:58
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Personally I don't like the set up. I much perfered the single breaker panel, however, if the problem that we had with it happened often then I can see why they got rid of it.
This year we were having problems with the cords going to our camera arcing, lukily this didn't hurt the camera. We traced the problem to the breaker panel were it was shorting the positive from the battery to the frame which then traveled to the camera mount, through the screws holding the camera board and back to the batteries through the wires that control the camera. If this shorting happened a lot then I can see why they got rid of the breaker panel.
Also, if you thought that 2004 was bad then 2003 would have caused you to cringe
Unread 03-02-2007, 02:05
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
We had this same problem!!! We mounted some of our victors with metal screws and one screw for a + wire was slightly loose causing it to hit the screw and charge our entire frame.
Unread 03-02-2007, 15:05
teddybear teddybear is offline
FRC #0234
teddybear is an unknown quantity at this point
I'm still learning all the aspects of mechanical engineering, so this is still all new to me. I doing my best and listening to all of our engineers. It is very exciting.
Power Distribution Block Wiring slimemonkey Electrical 11 04-02-2007 18:40
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Power Distribution Requirements kham Electrical 2 14-01-2006 12:35
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
