Go to Post This isn't about practical, it's about having fun and thinking outside the box... tetrahedron.... whatever....:rolleyes: - Cyberguy34000 [more]
Unread 03-02-2007, 01:51
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Team Role: Leadership
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
Hooking up a (1) potentiometer, (2) on-off switches, (1) 8-way switch
Hello,
So I am working on a custom OI box, and sadly have about zilch experience.
I need to hook up a (1) potentiometer, (2) on-off switches, (1) 8-way switch to one of the joystick ports.
I have reviewed the OI reference guide:
http://www.ifirobotics.com/docs/oi-r...de-1-30-07.pdf
But the fact is I am still unsure how to hook these up.
So the switches are digital, the potentiometer is analog. And that is about where I loose what to do.
Help?
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 03-02-2007, 11:29
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Hooking up a (1) potentiometer, (2) on-off switches, (1) 8-way switch
The Blue Alliance has many great tutorials on line and one of them is a how to on custom controls.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 03-02-2007, 14:01
AKA: Erik Thulin
That was quite helpful, thanks!
I understand just about everything concerning how to wire it, except for this; we need to hook up an 8 way switch, and there is, quite obviously, not enough digital switch inputs.
Some one told me that you can encode 16 positions into 4 digital inputs (binary) using routines or something like that, but I have no idea what they are speaking about.
Can anyone help me out in that regard?
Unread 03-02-2007, 14:15
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
http://www.chiefdelphi.com/forums/sh...oto=nextnewest
Try that topic specifically the post by Alan. . . 16 positions is a lot . . That would be a lot of resisters. . .
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 03-02-2007, 14:18
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Eric,
Connect your switch via resistors to an analog input to get 16 distinct levels on that input.
This topic has been discussed many times in the past on these fori. If you do a search on the words switch, resistors and analog you will find a number of threads on this topic.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 03-02-2007, 15:04
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
If you wanted really simple wiring, Joystick ports 2 & 4 each give you access to 8 digital inputs and 4 analog inputs. Using either one of those ports, you could use 7 of the digital inputs for the 8-position switch (one position would have nothing connected, and the other 7 positions would activate a different digital input), one digital for one of the on/off switches, one analog for the other on/off switch, and another analog for the potentiometer.
It would be really easy to wire with one of my wiring boards (See the Team 116 OI Adapter board thread and Web Page), or just wire it directly to a 15-pin cable.
If you want to conserve digital inputs, you could use an 8-position octal (3-bit binary) switch, and only use 3 digital inputs for the 8 position switch. You could also get eight 10.K Ohm resistors, and then use one analog input for the 8 position switch, where each position would add another 10.K ohms to the series resistance value, and the programmers would convert the 8 resulting analog ranges into 8 unique settings.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 03-02-2007, 17:27
AKA: Erik Thulin
Ok, so I see this:
Code:
pin 1 ----+---- switch 1 ----+---- /\/\/\/ ----+---- /\/\/\/ ---- pin 11
          |                  |       20 k      |       33 k
          +---- /\/\/\/ -----+---- switch 2 ---|
                 10 k
Looks perfectly feasible. So just to make sure I understand: I just keep increasing the resistance as I go from switch to switch? How high is the max?
Thanks,
- Erik
Unread 03-02-2007, 20:22
ECarlson's Avatar
AKA: Eric Carlson
Since you just need 8 distinct positions on one switch, you can put a 10.K resistor between each adjoining pin, then each position change will add (or subtract) 10.K ohms to (from) the value, and the value can essentially range from near 0 to 100.K ohms. The diagram you showed was for discrete switches, where any give switch could be on or off.
- Eric
Unread 04-02-2007, 15:16
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Kind of off topic, but where did you find your 8-way switch? One of these could be useful for us, or even a 5 way switch. Thanks in advance.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 04-02-2007, 16:59
AKA: Erik Thulin
We got ours from a local electronics supply store called "Vetco".
Unread 04-02-2007, 17:13
ECarlson's Avatar
AKA: Eric Carlson
Radio Shack sells a 6 position rotary switch for $3 in most stores and online: Model # 275-1386. If you want higher quality switches or a wider selection, Digikey, Jameco, and many other places sell them online.
- Eric
Unread 04-02-2007, 21:17
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
Brad, look maybe at guitar part stores like SamAsh or Guitar Center, but Stratocasters (Fender), have 5 way switches. Look at the electronics at StewMac for a whole bunch of cool electronics, like a push-pull potentiometer and stuff like that (i have two rigged to the LP im building for coil tapping). anyways, brad, here is the link to the site, http://www.stewmac.com/, and if you want the switches section directly, http://www.stewmac.com/shop/Electron...and_knobs.html
hope this helps.
anyways, yeah, resistors should do the job as mentioned. Sorry to shift the subject a little.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Best way to collect balls [off the field]? DonRotolo Technical Discussion 46 14-01-2006 15:15
pic: Another one from way, WAY up CD47-Bot Extra Discussion 18 01-05-2004 02:31
OFF TOPIC: av switch matt111 Electrical 2 21-03-2004 15:34
3 way toggle switch programming LeadRiccardoT Programming 3 17-02-2003 02:02
