Go to Post Those poor suckers on the West coast get three hours LESS sleep than we do afterward. Anyone else glad to see that crate go every year, regardless of what's in it? - Rich Kressly [more]
Unread 03-02-2007, 13:00
the_unknown the_unknown is offline
the_unknown is an unknown quantity at this point
Fuse Panel Question
To me this seems like a rather obvious question, but are we allowed to use only one (the larger one) of the two fuse panels FIRST provides? The wiring diagram has lead me to believe that we must use both of these panels.
Thanks in advance.
Unread 03-02-2007, 13:45
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
Re: Fuse Panel Question
If you're not planning on using your speed controllers at their full 40 amp power, you should be able to get by on the single panel.
Unread 03-02-2007, 13:49
I apologize for the confusion, I did not mean the MAXI breaker, I was referring to the two plastic fuse panels for the 20 and 30 amp breakers. ( 2 30 amp breakers, and 5 20 amp breakers will be required for my teams bot)
Unread 03-02-2007, 18:59
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
I always try to include both fuse panels even though they go largely empty. This way I can separate the RC power from any motor EMF interference that may occur on the power feeds, If weight or space is an issue, you can try one panel, but we usually have some external circuitry added that will reside on the smaller RC panel and not on the larger panel. Besides, having the open circuits allows for easier implementation of last minute enhancements without totally changing the electronics board layout.
Jim
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 03-02-2007, 21:49
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You can use either or both of the large or small black panels in your design. Some teams even choose not to use the large 40 amp block, using #14 and 30 amp breakers instead. It's up to you. However, my recommendation is to use the 40 amp breakers and #10 wire when feeding drive motors like the large or small Chalupas. Jim E has the right idea about feeding the RC power. If you have other high current motors on this panel, the RC breaker should be the first one closest to the power input stud.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 04-02-2007, 15:05
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
Team Role: Leadership
Rookie Year: 2007
seanl will become famous soon enoughseanl will become famous soon enough
at first we only used the larger one but it turns out we need them both because we ran out of space. so only use what you need. if u can get by using only the large one then do that.
Unread 05-02-2007, 13:02
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
Thumbs up Re: Fuse Panel Question
awesome- y'alls questions and answers helped me a lot. i was confused also as to whether we had to use both plastic distribution panels. thanks!
Team #996 Programmer/President/Comedy Relief
"Why not stop by the robotics meeting after school today?" -Mr. Murray (enlisting me)
Last year's fuse panel svanderlugt Electrical 1 03-02-2007 13:14
Fuse Block and Panel Dwgs indieFan General Forum 4 14-03-2006 01:39
Maxi 40 Amp Fuse Panel mtrawls Electrical 25 13-02-2004 15:19
Help with understanding Fuse panel Blue_Midnight Electrical 3 10-02-2004 23:12
First Cad Library- Fuse Panel Josh Hambright Inventor 5 19-01-2003 17:41
