Go to Post Remember, there are many differents path to obtaining knowledge. There's no need to pigeonhole the process. - Karthik [more]
Unread 03-02-2007, 13:23
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
Syntax Error
Im trying to compile my code in MPLAB, but when ever it comes to user_routines_fast.c it comes with an error
After the very end of the file, the compiler goes to the next line and then calls a syntax error. And if I comment that line out, it just goes to the next line and calls another error
How can i fix this?
Unread 03-02-2007, 13:39
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
Re: Syntax Error
It sounds like you're missing a closing brace somewhere. Short of seeing the code, make sure every opening brace, has a closing brace.. or that your last statement has a semicolon.
Unread 03-02-2007, 13:45
AKA: Kevin
FRC #0453 (Gears)
Re: Syntax Error
I checked all of that yet I am still getting an error.
It looks like this--
/* Add code to handle incomming data (remember, interrupts are still active) */;
(the code ends on the line above and a syntax error is being called on this line)
Unread 03-02-2007, 13:46
AKA: David Page
Re: Syntax Error
you've got a semicolon that's uncommented, what happens if you remove it?
Unread 03-02-2007, 13:48
AKA: Kevin
FRC #0453 (Gears)
Re: Syntax Error
I tried that and it still doesnt work.
Unread 03-02-2007, 13:54
AKA: David Page
Re: Syntax Error
message sent.
Unread 03-02-2007, 15:39
AKA: David Page
Re: Syntax Error
sizolved.
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
Array Syntax Error Andrew Blair Programming 7 05-02-2006 14:11
Syntax Error! Denz Programming 15 04-02-2006 23:57
Simple Syntax Error miketwalker Programming 6 06-01-2004 00:17
