Mounting Geartooth sensor!
This year they changed up our gearboxes with the Banebots 12:1 Transmission. I know how a gear-tooth sensor works and how it should be mounted in relation to a gear, I just don't know where what gear to mount it to. Does it go somewhere in the transmission or what? If someone could possibly take a picture of their robot w/ the gear tooth sensor attached and post it or e-mail it to me that would be very much appriciated.
Thanks in advance! |
Re: Mounting Geartooth sensor!
Aaron,
The gear tooth sensor is intended to count any rotating part that has indentations. A gear or sprocket is what is needed. You will have to make a bracket to hold it in place and position it experimentally until it counts and gives you valid data. The documents go into some depth on this part. Without a look at your robot, it is hard to give more specific suggestions. |
The gear tooth sensor will not give you direction info.
There is an add-on Banebot option for a quadrature encoder, that mounts on the outboard (wheel-side) shaft of the Banebot motor. |
| GearTooth Sensor Destroying Hopes of Autonomous~!!!!!! | Prgrmin' | Programming | 36 | 28-02-2006 19:07 |
| Mounting the Gear Tooth Sensor??? | blue_crew | Electrical | 3 | 09-02-2006 13:53 |
| Sensor Mounting Aplications | Jimmy Holmes | Electrical | 5 | 13-02-2005 13:34 |
| Sensor or no Sensor For Autonomous mode | Kyle1010 | Programming | 14 | 22-01-2003 13:10 |
