Thread Tools |
Rating:
Display Modes |
Re: How are you going to operate you're robot?
A joy stick for each side of the drive motors. Quite possibly 2 joy sticks for the manipulator (or 1 and some buttons). We're also going with a big red button (probably an easy button) with a cover for ramp deployment.
We have used one joystick for driving in the past and plan to this year also. Also usually an assortment of two position switches, three position, and sometimes rocker switches. This year we have a couple different things going on plus the board is looking good for once this year haha. We try to aim for making it easy for the operators and not making them have to look down too much to see what they are doing because then they aren't watching the field which can be a very bad thing.
Driver:
Steering Wheel for left right Joystick for throttle 2 of-on switches for ramp deployment Operator: 1 Joystick with uber-buttons. |
we're using:
steering wheel joystick for throttle two joysticks for arm control a big switch for ramp deployment and lift we may switch back to tank drive because the steering whell is having some issues, but no matter what we're using all 4 ports... |
Ours is 100% autonomous so we dont have to control it, were just gonna plug in the OI and radio and let her rip.
Our current plan (subject to change) is to have only 1 driver, along with the HP, a student tactician, and the coach. The driver will use an XBOX controller -- 1 JS to drive, the A/B/X/Y buttons for floor/lower/middle/upper, and the triggers for open/close. We'll also have two buttons on the OI board which must be pressed simultaneously to deploy the ramps.
I would like to see this.... done with a joystick. My question is why do you need any buttons on the O/I? You still have 6 more buttons available to you on the Xbox-controller. You could impliment the same logic using those. |
It's intended as a safety measure. Some people are concerned about accidentally deploying the ramp in the middle of the match, so we decided to put the ramp control far away from anything that might accidental get pressed.
Drivetrain: Joystick and a turntable...
Arm: ??? |
#10
For the main driver, we're using one joystick drive, with a kill switch to disable motors, a manual override to kill sensor assitance, a ramp deploy switch, and an extra switch either for raising ramps or for using the camera in manual mode.
For the arm guy, we're using a joystick for arm angle adjustment, the hat switch for claw angle adjustment, 5 automatic arm position buttons, 1 switch to switch which side of our robot the automatic buttons work for, an abort button to cancel auto arm movements, a switch to turn the compressor on/off, a button for our elevator, and then 2 buttons on the joystick for claw and extension control. Plus we've got 4 indicator LEDs. All in all we're using 4 analog inputs, 13 digital inputs, and 4 LEDs. |
#11
Ours is a very complex system of sensors on the skin of the driver, a biomechanical suit and several large anteaters.
Two joysticks and I have no clue on how to control the arm, maybe a big button to slam with your head? Chris |
#12
kiddin'. just two joysticks and a button. simple, easy, and it works ,too! [we hope ] |
#13
two joystics for driver, and we are going to have to find some buttons for manipulator contoll, as well as a big red "Don't press". And we'll call it the football.
#14
Our robot's base chassis is an omnidrive, complete with forklift, a gyro and a big claw. There are going to be 2 operators, one to drive and one to manipulate the tubes (unless they changed the design again...). Our gyro is to keep the robot on course, so if it's bumped, it will try to counter the bumping. our loose battery has been giving us quite a bit of strife... it mucks up the gyro and causes spurious movements.
#15
We're using an X-Box 360 controller both to drive and manipulate. Our driver tried it this morning (he was originally totally against using it) and found he loved driving with it.
| When are you going to release a full picture of your robot? Are you? | Elgin Clock | General Forum | 19 | 03-02-2008 01:08 |
| So how many of you are going to the Pittsburgh Comp? | RayleighxFace | Regional Competitions | 5 | 16-02-2007 11:30 |
| How far are you on your robot? | LionMane250 | Technical Discussion | 44 | 06-02-2007 11:48 |
| How much sleep are you going to get??? | ttedrow | General Forum | 34 | 11-01-2004 02:27 |
| Ok Lets See Some Pics Of Ur Robot, If You Are Going To Cleveland!! | Alex Cormier | Robot Showcase | 16 | 02-03-2003 17:40 |
