Go to Post The mission of FIRST is not just to promote science and technology, but to help every student involved to reach their full potential and achieve their dreams - Mike Ciance [more]
Unread 02-03-2007, 08:24 PM
Joobacca Joobacca is offline
FRC #0192
Joobacca will become famous soon enoughJoobacca will become famous soon enough
Question about Fisher Price Motor Connectivity:
Is it possible to hook up a Fisher Price motor to a Globe Transmission?
Thanks!
Unread 02-05-2007, 01:24 PM
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Question about Fisher Price Motor Connectivity:
Is is certainly possible to attach a Globe gearbox to the Fisher Price motor. You will need to replace the pinion gear on the FP motor shaft with the one on the Globe motor, then make a bracket to hold the two together. This will require some precision machining.
The FP motor has much more power than the globe, to I wouldn't count on the Globe gearbox lasting a long time. Make sure you strip it down and re-lubricate it with with quality grease. Most Globe gearboxes I have seen are pretty dry.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Fisher Price Motor Andrew Y. Motors 2 11-20-2006 07:52 AM
question on programming fisher price motor? waialua359 Programming 1 01-22-2006 09:11 PM
Question about Fisher Price Motors waialua359 Technical Discussion 4 01-21-2006 02:04 AM
Fisher Price Motor Mounting Ashley Weed Motors 1 02-16-2003 07:29 PM
Fisher Price Motor .. Important! Paul Copioli Motors 7 01-22-2003 01:55 PM
