Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
Unread 04-02-2007, 12:09
Gary Bonner Gary Bonner is offline
FRC #3974
Rookie Year: 2000
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
BaneBots 56mm Gearbox - Second Stage Sun Seizing
As we anxiously await the double D solution, we were running our base around yesterday and one of the gearboxes locked up. The other has intermittent high-friction spots. We are using the two CIM adapter and the 16:1 conversion. Upon disassembling the locked gearbox, we found that the last sun gear had seized on the output shaft. In the working gearbox, the last sun gear can spin, but not freely. The end of the output shaft was rough, and a groove was worn inside the sun gear. Is it necessary for the sun gear to ride on the output shaft? Can the end of the shaft, just above the double D, be cut off?
Banebot 56mm gearbox - double D - V3 - It's Show Time. Joe Johnson Motors 34 18-02-2007 19:00
Banebot 56mm gearbox - double D - RELOADED Joe Johnson Motors 82 09-02-2007 14:07
New Banebots 56mm transmissions for sale fsracer Motors 1 07-02-2007 22:58
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
