Bumper Mounts
How do you mount your bumpers? 1351 is currently in discussion about the best (and strongest) way to attach them.
thanks, Sam |
Re: Bumper Mounts
It would depend on how you would mount your chassie and what material it would be made out of. You could screw them to it or go as simple as zip ties which are really light.
Re: Bumper Mounts
The Tips and guidelines has some discussion on this subject. I saw all kinds of attachements last year but the ones that impressed me the most used a piece of aluminum angle drilled for mounting holes with bolts through the bottom of the chassis. The best one used eye bolts on the back of the bumpers which simply dropped over threaded rod on the chassis and attached with butterfly nuts. No tools needed and it only took a minute or so to remove for weigh in.
Re: Bumper Mounts
Are we allowed to use zip ties to mount the bumpers?
Re: Bumper Mounts
No. The GDC is very strict on the bumpers this year--it has to be something like a bolt-and-nut system.
Re: Bumper Mounts
We use these with 1/4" 20 bolts. You just drill a 1/4" hole into your plywood and smack them in. Note that they need to go on the INSIDE of the bumper so that the bolt pulls them into the wood.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK019 Last edited by TubaMorg : 10-02-2008 at 22:17. Reason: Image link didn't work |
Re: Bumper Mounts
as long as the wooden backing of the bumper sits flush with your chassis, the bumper mounts only have to hold it in place. Any force imparted on the bumper should be translated to the chassis, not to the mount. We use 1/4 inch aluminum angle. We may even downgrade that to save on weight. Sam |
Re: Bumper Mounts
Team 1726 has used either t-nuts (which can be hammered into a wooden board) or t-bolts to mount their bumpers. A quick McMaster search will show the various hardware. Considering the directions in which force will be applied to your bumpers you shouldn't need an incredibly tough mounting system as most of the force will be transmitted right on through as noted above.
You should be more worried if your bumpers are unsupported in the center as they may shatter. |
Re: Bumper Mounts
We used 1/4-20 carriage bolts hammered in the spec-size plywood through a 1/4" thru-hole. Typically, only 2 bolts per bumper are needed. The square shank under the head bites into the plywood and keeps the bolt from turning while being tightened. The bolts ran through holes drilled into the side frame members (1.5"x1.5" welded aluminum tubing frame) and fastened by wing nuts that are hand tightened (i.e. no tools).
We might look into using that ourselves--thank you!! ![]() |
#10
Re: Bumper Mounts
Last year, a member of another team told us that we shouldn't leave any mounting hardware on the bumpers apart from the bolts and/or nuts. I am beginning to doubt whether we would've failed inspection had we left our angles on the bumpers.
Is it legal to leave some light mounting hardware on the bumpers for inspection? |
#11
Re: Bumper Mounts
Re: Bumper Mounts
#13
Re: Bumper Mounts
Re: Bumper Mounts
What you describe sounds like the spacers should stay with the robot for weight and size. The inspector at your events will make the final decision once he or she examines your robot construction. Please plan accordingly. |
#15
Re: Bumper Mounts
This is our bumper mount system. The hex shaped standoffs are bolted to the chassis, and touch the bumper, but do not attach to it. The long coupling nuts in the corners are threaded onto the "fanged elevator bolts" that are mounted inside the bumpers. We used the long nuts to make it easier to handle the nuts without dropping them into mysterious crevices, and to have a lot more area to put the wrench on them.
| Nypro Mounts | Chris Dibble | Motors | 2 | 12-02-2004 16:32 |
| Plastic Motor Mounts? | Tonay K | Motors | 4 | 09-02-2003 20:28 |
| Motor Mounts | Eugene | Technical Discussion | 1 | 07-10-2002 22:20 |
| Control System Mounts? | archiver | 2001 | 11 | 23-06-2002 23:33 |
| Motor Mounts | archiver | 2001 | 3 | 23-06-2002 23:29 |
