Go to Post Steal from the best, and then invent the rest! - dlavery [more]
Unread 04-02-2007, 14:28
ThatIndianKid89 ThatIndianKid89 is offline
FRC #0611
ThatIndianKid89 is on a distinguished road
Planetary Gearbox Possibility?
Question.
Is it possible to hook up a 3" CIM to the planetary gearboxes included in the kit? I know it's possible to use the 2.5" CIMs but we're thinking about using the 3" CIMs for more torque/speed.
Unread 04-02-2007, 15:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Planetary Gearbox Possibility?
I think your reason there might be a bit flawed. The large CIM motor (one of them) is less powerful than the small CIM motor (one of them). If you put a large CIM into a the planetary, you will get more torque, more weight, less speed, less power, and a larger risk of failure (due to the increased torque).
Can it be done? Yes. Would I recommend it? Probably not.
What is the application?
Unread 04-02-2007, 15:12
FRC #0611
huh.
thanks for that. lol. That actually helps us out a bit. Do you know off-chance what kind of fps we can get off of the 2.5" hooked up w/ the planetary? (this is all for our drivetrain by the way)
Unread 04-02-2007, 17:18
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Wink Re: Planetary Gearbox Possibility?
Originally Posted by ThatIndianKid89 View Post
huh.
It depends on if/what reduction you have after the gearbox, and what size wheels/pulleys you are using. But, the Banebots transmission has a 12:1 reduction (can be changed to 16:1 with a kit from Banebots), and the free speed of the 2.5" CIM is 5500 RPM. Under drive-train load, you can probably expect around 4320-4400 RPM. If you don't do any further reductions and are using the 6" Kit of Parts wheels, that would translate to about 9.4 (4320 rpm/60 = 72 rps /12 = 6 rps*6pi=113.094 ips/12=9.425 fps) feet per second (probably a bit lower depending on how inefficient your drive system is).
Being correct doesn't mean you don't have to explain yourself.
Unread 04-02-2007, 15:16
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Question.
The 3" CIMs have more torque, but not more speed. In fact the larger CIMs are only have about 80% the power of the smaller CIMs. Bigger is not always better.
That said, anything is possible.
We looked at mating the 3" CIM to the 56mm banebot transmissions, but decided to solve our problems in a different way.
This what we found out.
The shaft diameter and length appears to be correct.
The shaft should be keyed.
We removed the long bolt from last years 3" CIM so that we would have two long bolts to make it easier to mount.
The mounting plate on the transmission would have to be modified to accept the bolts from the CIM.
Keep in mind that we did not actually make make the necessary modifications, so I am not sure other problems might come up.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
possibility of collaborative scouting through LAN? efoote868 Scouting 24 07-12-2006 19:47
Low Cost Planetary Gearbox Source... Joe Johnson Motors 32 14-11-2006 18:02
Need some legality/possibility advice... IrishFBall32 Control System 3 26-04-2005 23:53
Possibility of a Team Party @ BattleCry? (EOM) archiver 2001 0 24-06-2002 03:43
Possibility of FIRST game in water patrickrd Rumor Mill 20 06-06-2001 15:31
