Go to Post Indianagineers! (n.: In-di-ae-nah-jih-nir: any resident of Gary, Indiana, or it's suburbs, who is trained in the use or design of machines or engines, or in other areas such as electrical or chemical technology) - dlavery [more]
Unread 04-02-2007, 15:00
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
Team Role: Leadership
Rookie Year: 2007
seanl will become famous soon enoughseanl will become famous soon enough
do we "NEED" the power distribution block
does the rules require us to use it or is it optional. because personally i see it as a waste of space and weight.
Unread 04-02-2007, 15:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: do we "NEED" the power distribution block
We all do. But, it is required, and you will not pass inspection without it.
Unread 04-02-2007, 15:07
seanl's Avatar
Rookie Year: 2007
yay time to rewire.
Unread 04-02-2007, 17:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
yay time to rewire.
Please check the Tips and Guidelines for instructions on how to wire this critical part.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 04-02-2007, 23:09
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
do we "need" it? I'd say not; I can't see how it's application is remotely close to a robotics competition, where weight is a major factor in it.
But, since the rules are the rules, yes, you must have it in your robot. so you do "need" it.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 05-02-2007, 01:50
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
Rookie Year: 1999
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
I have a question about that power block. Does it add any type of safety advantage? I'd hope that FIRST wouldn't purposely add required weight without cause. I'm only asking because I truly can't see the advantage of having it over not having it.
Unread 05-02-2007, 07:51
Unsung FIRST Hero
Rookie Year: 1996
Although I wasn't part of the process, I can't answer for First. However, this type of block is in constant use in the electrical industry and is quickly becoming a system desired by many Electrical Engineers. In addition to the blocks which you are now familiar with, relays, timers, circuit breakers (even 3 phase and motorized trip) computer interface, power supplies, etc. are all becoming available for use with the DIN mounting rail system. Other then the added weight and larger size than the IFI panel (which was a perfect match for our robots) this panel may make it easier for rookies to get wired up with a minimum amount of tools.
Al
WB9UVJ
www.wildstang.org
Unread 05-02-2007, 10:41
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Here's my view on this:
Is it an improvement on the IFI panel? Definitely not. That was a nearly perfect for our robots and its a shame to not be able to use it.
However, I would say it is an improvement over the 2k4 system - as it adds the ability to ground the 40A motors to something other than the FASTON connectors on flimsy 20/30A block, and allows you to eliminate the FASTON's from the high current motors (we use Anderson Powerpoles everywhere instead). It also eliminates the "stacking" of ring terminals for the 6ga connections that could be more likely to cause intermittent connections (as multiple ring terminals on a single stud means more possibilities of moving wires, more likely that the nut will loosen). The weight is annoying - but not as annoying as the 40A MAXI block. It also removes more 6ga ring terminals from the system and replaces them with simple set screw system, which is easier to terminate correctly than a large crimped ring terminal.
But oh well, we have to live with it.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 05-02-2007, 14:03
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Has anyone found a distributor for the Rockwell Block?
Personally, I am trying to give this thing the benefit of the doubt. I, like everyone, I guess, preferred the 2005 all-in-one solution, but we gotta roll with what first gives us.
One quick note - we have discovered that it's easy to think that you have the 6 AWG wires in place without actually having a solid connection, so be sure to open the screw up all the way, and to give the wires a serious tug after you screw them down. Otherwise, you might see battery wires heating up, and large voltage drops with high current draws.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 05-02-2007, 14:28
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Our local Rockwell Automation distributor does not have any in stock. Minimum order of each item is 50.
If somebody could find a distributor that stocks them, that'd be great. Otherwise we might try to pool an order.
Unread 05-02-2007, 20:55
youngWilliam14's Avatar
youngWilliam14 youngWilliam14 is offline
Team 461 Electrician and Operator
AKA: Will Crabtree
FRC #0461 (Westside Boiler Invasion)
Team Role: Electrical
youngWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud of
Send a message via AIM to youngWilliam14
I'd just like to know one thing: are we allowed to cut the yellow jumpers to fit just two or three blocks? I'd love to get rid of the red and black blocks that I won't be using.
"C.N.C." lyrics/"Driving on Regolith" lyrics
Let's all go nuts! Robots! Robots!--Team 461 chant
Power Distribution Block Grounding Karma Electrical 15 22-01-2008 07:18
Question:Power Distribution Block Pavan Dave Electrical 35 20-03-2007 20:10
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
