Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
Unread 04-02-2007, 21:21
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
pic: Team 1225's unfinished bot!
Unread 04-02-2007, 21:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: pic: Team 1225's unfinished bot!
This is enlightening. The electronics take up even more space than I thought. Hrrm. Seems like you have a lot of them. What are they being used for?
Unread 04-02-2007, 21:44
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Is that two wheel drive? And is your robot gonna weight 50lbs when its done?
I really want to see what your gonna do with this one.
Min-Max to the Max!
Billfred's Avatar
Billfred Billfred is offline
I'm always glad to catch a look at 1225's robot. (My mom's side of the family is from there; my cousin teaches math at East Henderson, and her husband is the football coach at Hendersonville High. 1293 also had a pretty awesome match with them at Palmetto last year.)
I've sort of been turned off by caster robots in the past, but they've been known to work wonders in the right hands. The one thing I might suggest is flipping the sprockets on the wheels around so they point inboard; doing so brings the sprocket on the BaneBots shaft closer in, which would cut down on side loads on that shaft. (The bearing block would also be a good idea, if you can fit it in, but the sprocket flip is free.)
Unread 04-02-2007, 22:20
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
You sure have a lot of relays on there!
Unread 04-02-2007, 22:58
Molybdenum's Avatar
Molybdenum Molybdenum is offline
AKA: Theo Kunicki
FRC #0694 (StuyPulse)
Molybdenum is just really niceMolybdenum is just really niceMolybdenum is just really niceMolybdenum is just really nice
I think it's fair to assume that we should expect some crazy pneumaticness?
Unread 04-02-2007, 23:18
AKA: Alex
Crazy pneumatics? Yes!
Most of the electronics are for the pneumatics. We're going to try and build an articulated arm.
Hmm Billfred, I took gym from B.J. Laughter last year. I think I remember you from competition at Palmetto last year. Nice to see you again. Team 1225 wishes you luck with your team. Thanks for the suggestion, it sounds like a good idea. We'll run it through the mechanical team.
Amperage Robotics Team 1225
Site under-going revamp. :/
Team 1225's Website pheadxdll Website Design/Showcase 7 26-01-2007 15:13
pic: 1726 Unfinished Parts MrForbes Extra Discussion 6 26-01-2007 00:14
pic: 179's Control Box (unfinished) CD47-Bot Extra Discussion 14 11-03-2004 10:52
Image Discuss: Maclay Robotics Team 654 - Unfinished CD47-Bot Robot Showcase 3 26-04-2003 13:39
Image Discuss: team 27's field, unfinished. CD47-Bot Extra Discussion 4 13-02-2003 09:14
