MPLAB/c18 not creating a .hex file
Basically, the topic. I believe it's a problem with the project settings, as it only happens with certain robots' codes. It will compile, create .cod & .coff files, mysteriously omit the .coff to .hex conversion, and declare the build complete.
What would this be caused by? I have no idea where to start, so info on settings will be provided on request. Thank you ^_^ |
Re: MPLAB/c18 not creating a .hex file
There is a setting to supress the creation of the hex file. In MPLAB, go to Projects -> Build Options -> Project -> MPLINK Linker and verify that INHX32 is selected.
It is.
Could be the "Output Directory" is set in
Project -> Build Options... -> Project to be some place other than the current directory. |
That wouldn't cause the linker not to even output "cod to hex converter" (or whatever the exact wording is...) though, would it?
I encountered this same issue with Smithtown a couple of year's ago and I'm trying to remember how we fixed it. They had played around a lot with the settings and had specified where intermediate directories, etc. were located instead of taking the installation defaults. It may have been a matter of taking all the defaults or reinstalling MPLAB/C18 to get all the default settings back, but based on your experience of it happening with some files and not others, I suspect we must have recreated the projects as well to correct the project specific settings. You can run mp2hex.exe from a command line in case it gives you any more useful information. Last edited by Mark McLeod : 09-02-2007 at 09:56. |
OK, I'll give that a shot when I'm back in school tomorrow, Mark
Well, running mp2hex.exe did nothing....
...because the path was too long -_- The projects that weren't getting hexes made were the ones whose paths were longer than 62 characters...always read carefully ![]() Thanks for the help, all. |
| creating hex file | seanl | Programming | 4 | 03-02-2007 22:08 |
| "Error.MCP" file after HEX file trans | iwdu15 | Programming | 1 | 24-01-2007 20:05 |
| hex file garbage? | sciguy125 | Programming | 2 | 04-07-2005 23:04 |
| MPLAB C18 problem | Justyn | Programming | 0 | 09-03-2005 11:37 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
