Go to Post All I have to say is --- Life == FIRST - Lora Knepper [more]
Unread 05-02-2007, 18:43
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Problems integrating CMUCAM code and IFI Default Code
We've had problems with integrating Kevin's streamlined v2.1 camera code into the IFI default code for 2007. I followed the instructions in the readme(s) from the camera code, and when I had finished, there were no code errors. When I finally downloaded the .hex file to our robot, which was working fine before, I got a code error and nothing would respond. Is it possible for the IFI 2007 code to even be integrated with Kevin's camera code, and, if so, is there any way to figure out what I did wrong in combining the two. The camera.c and camera.h files are both in the project. Also, when I first built it, I had 2 errors, but when I took them out, it compiled fine. Any help would be nice.
P.S. We tried using Kevin's default code instead of the IFI code and we couldn't get it to run.
Unread 05-02-2007, 23:57
kitscuzz's Avatar
kitscuzz kitscuzz is offline
Not alotta posts
AKA: Kit
FRC #1389 (Worst Case Scenario)
kitscuzz will become famous soon enough
Re: Problems integrating CMUCAM code and IFI Default Code
Are you putting this onto the 2007 Robot controller? The code for 2006-2007 won't work on boards from before 2006
If you are using the current board, try just compiling the default streamlined code with none of your own and see if it compiles and uploads and runs without error. If it doesn't run (as you've indicated) give some extra information. What exactly goes wrong? Does the red light that indicates a code error light up?
If you can't get Kevin's code to run on its own, then you won't be able to run it integrated either.
Unread 06-02-2007, 16:48
Windward's Avatar
FRC #1452
Sorry. I forgot to mention it, but we did get the streamlined camera code working before we had finished building the robot. We were using a different circuit, but the same code, O/I, RC, and everything else. It was working perfectly.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
2007 IFI default code question Japper Programming 4 22-01-2007 23:23
New IFI Default/User and Master Code Alex698 Programming 6 28-02-2006 23:04
CMUcam default code not responding Kyveck Programming 29 26-01-2006 16:25
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
