Go to Post In theory, this should work... Oops. - Eldarion [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 05-02-2007, 19:06
acumenerratica acumenerratica is offline
w00t-machine
#0870 (Team RICE)
Team Role: Scout
acumenerratica is an unknown quantity at this point
Send a message via AIM to acumenerratica
Filemaker Help?
I'm working on a FileMaker database for scouting this year. However, I've never used FileMaker before.
What I'm trying to do is set up an entry field of different metrics that are entered match by match for a specific team.
For example, if you were scouting Team xyz for match 1
you'd enter xyz as the team #, 1 for the match # and fill in the various parameters.
So far I have the entry fields set up, but I was wondering how to set up the records so that I can do the following:
>>Use the same form to enter each match (over several computers)
>>View ALL the match data sorted into groups of team, then match #, so if you looked up team xyz, you'd see a list of matches they were in, what teams they were with/against, and what they did in each match
>>network this database (i don't need as much help with this one)
"In the race between the rock and the pig, do not varnish your clams."
[IMG] code is Off
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
FileMaker Scoring Database Jamie_Richard General Forum 3 08-03-2004 08:42
Filemaker, how do you share on 4 computers? Quentinfool Scouting 8 06-02-2003 14:29
please help! anyone not using Filemaker Quentinfool Scouting 0 04-02-2003 21:53
