Go to Post If you thought two alliances racing to tip the bridge in auto was exciting, wait until they play autonomous chicken on the center line. :D - Alpha Beta [more]
Unread 05-02-2007, 19:37
Maximus123's Avatar
Maximus123 Maximus123 is offline
Maximus123
AKA: Crimp
FRC #0425 (Team Spartans)
Team Role: Leadership
Maximus123 is an unknown quantity at this point
Send a message via AIM to Maximus123 Send a message via MSN to Maximus123 Send a message via Yahoo to Maximus123
Question 3rd pressure gauge?
in the pneumatics manual it shows in the diagram 3 pressure gauges but the inventory list only shows 2 of them and we recieved 2. were going to use the setup on the diagram, but like i stated we only recieved 2 gauges. how can we do it with out it, or if we need them, can we use any gauges? i no i usually quote and stuff, but were extremely busy here
Unread 07-02-2007, 00:30
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: 3rd pressure gauge?
You don't need a third one. The Monnier regulator and gauge on the schematic is only if you want different pressures of working air for different parts of your pneumatic circuit. Chances are you won't need it. Just forget it's there if you are using the diagram for design.
Just make sure you have one gauge on the air storage side (which should go up to 115-125psi), and one on the working air side (up to 60psi).
[OCCRA]: Gauge JonMTeam255 OCCRA Q&A 1 24-09-2004 19:01
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
What gauge wires Punjabguy87 Electrical 7 07-02-2004 20:25
11 Gauge Wire...where? Matt Krass Electrical 6 21-01-2003 10:17
