Go to Post Tank tracks are one of those things that keep showing up on FIRST robots, in ways that I dont understand. - KenWittlief [more]
Unread 05-02-2007, 21:41
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Victor Braking Feature
We want our arm to freeze when the joysticks are in neutral. I changed the jumper on the victors but it still does not work. Can anyone shed some insight on this?
Unread 05-02-2007, 21:48
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Victor Braking Feature
it is hard to have the motors "freeze". That is not what the jumper setting accomplishes. The following is from memory, don't take my word on it...
one setting feeds the power generated by the motor spinning back into the battery
the other one, "dynamic braking", feeds the power back into the motor with reversed polarity, causing it to slow down faster
So dynamic braking will not stop your arm from falling down, but it might help with preventing overshooting. To prevent falling, you have to power the motor slightly "upwards". You can either do this with programming (recommended) or by "calibrating" the joystick until the arm stops.
Unread 05-02-2007, 21:51
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The Victor "brake" feature uses what's known as dynamic braking. It connects the motor leads together. The braking force increases as the motor speed increases, but when the motor is not moving there is no braking force. It will slow down and perhaps even stop a moving arm, but as soon as the arm comes to rest it will move again easily. It'll stop again, or at least move more slowly than without the brake jumper in place, but it won't stay stopped. Basically, you can't "freeze" a motor with dynamic braking.
Unread 05-02-2007, 21:58
Software Architect
Originally Posted by tdlrali View Post
...To prevent falling, you have to power the motor slightly "upwards"...
Be very careful when choosing this option. The motor will be stationary, and a stalled motor draws a lot of current. Some motors will be okay with that for a while (I think the window motor is one). Others will heat up quickly but should survive because they're massive, like the CIM minibike motor. But others will fry if they're powered for very long without spinning -- the scent of a smoking Globe motor is familiar to many.
The other options are to provide a mechanical brake or to use a gearing system that won't backdrive.
Unread 05-02-2007, 23:31
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
I think the issue you are having is with motors backdriving. The window motors and the denso are the only motors I know of that do NOT backdrive. Other wise, you'll need constant current as described above.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 05-02-2007, 23:43
Basically, any worm drive will not be backdriveable
Another option, although this is almost never possible on robots, is a counterweight
Unread 05-02-2007, 23:45
KTorak's Avatar
Fire Rescue 47
AKA: Kyle Dersch
Team Role: Driver
I almost made that generalization, but I wasn't 100% sure. Thanks!
Unread 06-02-2007, 14:38
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
In reality, you can backdrive some worm gears. It's a function of the lead angle and the efficiency (which is itself dependent on material, finish, lubrication, wear, etc.). If you want to really be sure, test it with an equivalent torque, and see what happens. Also consider that the gear may wear out over time, and can begin to behave differently.
You're on the right track, though; locking the mechanism with a worm gear is better than stalling your motor to hold it in place.
Victor Braking patTeam241 Electrical 5 21-01-2005 14:00
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Dynaminc Braking on Victors Max Lobovsky Control System 7 06-02-2004 13:43
Victor braking feature MattB703 Electrical 12 21-06-2002 07:26
Cool feature... Joe Johnson CD Forum Support 4 01-06-2001 16:45
