Go to Post Getting your questions answered is what the big thick manual is for....GO READ. - Dorienne [more]
Unread 05-02-2007, 22:28
zim2411's Avatar
zim2411 zim2411 is offline
AKA: Peter Harris
FRC #1727 (Rex 1727)
zim2411 is a jewel in the roughzim2411 is a jewel in the roughzim2411 is a jewel in the rough
Multiple actuators per solenoid?
I combed through the manuals on pneumatics, and I couldn't find any mention of this, but I probably just missed it.
We need to have 4 linear actuators go off at once, in addition to other pneumatics parts on our robot. We only have 4 double solenoids available (the SMC ones) so my question is, can we hook up a T fitting after the solenoid to allow multiple actuators going through one solenoid? I know we can hook multiple solenoids up to a spike, so that isn't the problem.
Unread 05-02-2007, 23:13
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Multiple actuators per solenoid?
Yes, you can connect multiple Bimba cylinders to a single solenoid via T connections. However, you mentioned "linear actuators" which is the industry buzzword for specialized devices which are not allowed on a 2007 FIRST robot. The only "actuators" you are allowed are the Bimba cylinders listed on the last page of the 2007 Pneumatics Manual.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 06-02-2007, 10:18
zim2411's Avatar
AKA: Peter Harris
Ah sorry, I mean the Bimba cylinders. Thanks for the info!
Unread 06-02-2007, 10:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Just remember that you are dividing the air between the cylinders hooked up to the same solenoid kind of like dividing the current in a parallel circuit. It’s also a good idea to use the flow control fittings so you can balance the speed of the cylinders.
You can also purchase more solenoids if you need to.
actuators Transformers Pneumatics 1 27-01-2007 02:48
Multiple cylinders on a solenoid robogeek753 Pneumatics 5 12-01-2007 00:06
actuators KillerCows456 Technical Discussion 1 18-01-2006 17:04
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Rotating Actuators? turbidum Rules/Strategy 3 12-02-2002 02:47
