Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 06-02-2007, 08:59
buddy.smith buddy.smith is offline
Master Control
FRC #1795
Rookie Year: 2007
buddy.smith is an unknown quantity at this point
Vex encoders/Interrupts
Hi,
Has anyone used the encoders with the Vex bot? We're using a Vex platform for prototyping so that the programmers can work on the drive code while everyone else builds the real thing.
If I use Kevin's encoder code with the Vex encoders, or if I use EasyC with the Vex provided encoder code, I don't quite get what I expect!
Interrupt 1 comes up as Encoder 2 (Kevin) or Interrupt 2 (Easy C)
Interrupt input 2 comes up as Encoder 4 (Kevin) or Interrupt 4 (Easy C)
3 comes up as 6, and I can't find the rest of them.
This happens on at least 2 Vex controllers, so I'm sure it's not a bad controller.
Does anyone know for sure what ports the Interrupt pins map top, or do I need to disassemble my controller and map it out with a meter?
Has anyone successfully used 4 encoders on a Vex bot, all connected as interrupts?
ttyl,
--buddy
Interrupts JSonntag Programming 1 14-01-2006 12:43
Vex navigation with ultrasonic and encoders GlennGraham Electrical 4 13-01-2006 12:58
VEX Optical Shaft encoders in FRC sanddrag FIRST Tech Challenge 8 04-10-2005 07:52
Encoders, interrupts, and edge-triggering issues Alan Anderson Programming 6 11-03-2005 16:06
Interrupts CyberWolf_22 Control System 3 12-01-2004 21:46
