Go to Post your bot brings all the boys to the yard. - looneylin [more]
Unread 06-02-2007, 16:31
Pankowgears Pankowgears is offline
FRC #0453
Pankowgears is an unknown quantity at this point
anybody have a schematic for air tanks? (was: i have a question)
Does anyone have a scemactic for just air tanks?
Unread 07-02-2007, 00:27
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: anybody have a schematic for air tanks? (was: i have a question)
Do you mean a pneumatic circuit schematic using just pre-compressed air tanks and no compressor?
Or do you mean a blueprint/CAD drawing of a physical air tank?
Unread 07-02-2007, 01:01
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Use the schematic on page 11 of http://www2.usfirst.org/2007comp/oth...s%20Manual.pdf
Remove the compressor package, and just plug the end of the Clippard Air Receiver Cylinder to which it is attached. You may also remove the Nason Pressure Switch. EDIT: You may NOT remove the nason pressure switch, as per R101. Thanks to those below who caught my oversight. R103 also insists that the compressor be controlled VIA Spike by the RC.
Now you have a FIRST-Legal pneumatic circuit. To charge the system, connect your compressor's output to the Parker System Pressure Vent Valve (with a piece of tubing and a quick connect... remember to attach the pressure relief valve to the compressor before you do anything with it!). Open the Pressure Vent Valve. Run the compressor until the system is charged (120 psi). EDIT: Control this using the NASON pressure switch and the program on your RC. If you don't reach 120 psi you may need to adjust the pressure relief valve on the compressor... if you exceed 120 psi, you will DEFINITELY need to adjust your pressure relief valve. EDIT: Generally pressure relief valves do not need adjusting, and are not allowed to be adjusted from their set point.
Turn off the compressor, close the vent valve. Detach the compressor.
You have a charged pneumatic system.
Good luck, and have fun,
Jason
Unread 07-02-2007, 15:17
FRC #0453
yes, we need the schematic for pre-compressed air tanks, and not the schematic that first gives us.
Unread 07-02-2007, 15:36
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Now you have a FIRST-Legal pneumatic circuit. To charge the system, connect your compressor's output to the Parker System Pressure Vent Valve (with a piece of tubing and a quick connect... remember to attach the pressure relief valve to the compressor before you do anything with it!). Open the Pressure Vent Valve. Run the compressor until the system is charged (120 psi). If you don't reach 120 psi you may need to adjust the pressure relief valve on the compressor... if you exceed 120 psi, you will DEFINITELY need to adjust you pressure relief valve.
You might have trouble with this setup, I seem to recall that we did this last year and needed to make some changes to pass inspection. We used the pressure switch to tell the controller to turn on a spike when pressure was below 120 psi (or whatever it is set at), then connected the spike to the compressor with quick connect terminals. We had to add a TEE and another manual valve to discharge the air from the compressor to manual valve hose, so we could safely release the pressure before disconnecting the compressor hose.
I may be wrong on the details....but the point is that the system you described might not pass inspection at all events, so be prepared to do it differently.
Unread 07-02-2007, 15:57
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Jason
Jason,
Some comments on your advise...
As per rule <R101> you may not remove the Nason Pressure Switch from the robot. It must be connected to the RC and must shut off the compressor (at about 115 PSI) before the pressure relief valve actuates (about 125 PSI).
As per rule <R102> you are not allowed to adjust the pressure relief valve.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 07-02-2007, 16:00
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
Originally Posted by squirrel View Post
...We had to add a TEE and another manual valve to discharge the air from the compressor to manual valve hose, so we could safely release the pressure before disconnecting the compressor hose...
Jim,
Your advise is well put. It is not spelled out in the rules but it is certainly a safer way on implementing an off-board compressor.
Mike
Mike Betts
Unread 07-02-2007, 17:19
AKA: Jason Brett
Originally Posted by Mike Betts View Post
Jason,
Regards,
Mike
Thanks... my advice did ignore R101... it was written late at night, but I have edited the original post to highlight this oversight. As for R102, however, our pressure relief valve (for the first time, I might add) was not tight when it arrived and would release at less than 100 psi. It was necessary to adjust it to return it to FIRST specs, and it is now tightly locked in place at 120-125psi.
Jason
Unread 07-02-2007, 17:56
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
Jason
Jason,
You (and anyone else having this problem) should post this information to the FIRST Q&A. They need to realize that this is happening and revise the rule accordingly.
Mike
Mike Betts
Does anyone have a schematic for the operator's panel? DHarris Technical Discussion 1 28-01-2006 10:46
Anybody have a code for an autonomous mode to go to the 50 point bar???? and... chaoticprout Programming 9 06-11-2004 12:22
Anybody have ANYTHING from SPBLI or Philly? DaBruteForceGuy Regional Competitions 2 07-04-2004 22:33
Looking for gears - anybody have these? JamesJones Technical Discussion 4 04-02-2004 14:32
does anybody have pictures from 1999? Alex Cormier General Forum 6 13-01-2004 12:25
