Go to Post The low bar will make your electronics team cry. - Joe G. [more]
Unread 06-02-2007, 18:36
iwdu15 iwdu15 is offline
FRC #0811
iwdu15 is an unknown quantity at this point
sending extra information to the OI
hi, im trying to send extra information to the OI and (hopefully) to a computer attached to the OI for use during competition.....how can i send this information across the radio to the OI and then to the computer? thanks
--iwdu15
--team 811
Unread 06-02-2007, 18:52
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: sending extra information to the OI
Do you already have a working Dashboard implementation running on your computer? If not, check out the information provided in the whitepapers section, especially this one.
Once you have that up and running, you have a few "user bytes" you can send data back through, but that limits you to 4 bytes of information. But the Dashboard Spec also sends back information about all the PWMs and the Relays and such. So if you need to send back more data, you can just stick it in some unused PWM variables and read it off on the other side.
Unread 06-02-2007, 20:05
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Also, what I have done in the past is to multiplex the data. It works quite well, and I could transmit 50 or so bytes of data that way.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Coercing McMaster into sending me a catalog. Rickertsen2 General Forum 32 30-03-2006 11:20
Sending variables to Auto Mode Adrien Programming 4 19-02-2006 21:51
Sending data back to the OI DanDon Programming 13 26-01-2006 15:17
Sending Data Raven_Writer Programming 8 11-09-2003 16:28
Sending in your finished animation Tyler Olds 3D Animation and Competition 3 10-02-2003 23:08
