Go to Post DONT USE ROBOTS FOR EVIL!!! - Cooley744 [more]
Unread 07-02-2007, 13:12
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Reliable way to detect disconnected controller
We've been using the chicklet with great success for two different controllers.
We recently moved into using enough buttons that using the "digital buttons mapped into an analog channel" feature was necessary (> 4 buttons).
When programming to this, it became apparent that there wasn't an easy and reliable way to tell if the values you were decoding were actually the button presses versus "junk" when the controller is unplugged.
This stems from the fact that the OI puts analog channels at 127 when disconnected (this appears as button 1 always pressed). Likewise in autonomous.
With the chicklet connected, but the controller/peripheral disconnected, the value hovers around 126, 127, 128. In software this, of course, looks like alternating presses of button 1 and buttons 2, 3, 4 together.
Now... is this a big deal? Not really, but it is something to be aware of if you use the "digital buttons in an analog space" for potentially hazardous robot controls (drive train go really fast, for example). We've had cases where robot is on and enabled and a controller is loose/unplugged in the past.
Anyone come up with creative ways to detect if the controller is actually present?
Unread 08-02-2007, 18:03
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Reliable way to detect disconnected controller
You are correct. This will always be an issue when using the analog pins for digital data. The best approach is to ensure that your device is properly connected an has detected and connected your gamepad/joystick (green LED) Even with these precautions in place, a joystick can still be accidentally disconnected during match play. My advice is to not attach any dangerous or irreversible functionality such as ramp/lift deployment, to the high bit.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 09-02-2007, 10:14
Ok, I have an update for you. There is a way to detect if the device is disconnected. .
Ok, The Chicklet stuffs digital data in the following format:
Only the High nibble is to be used, the lower nibble is assumed to be garbage. The MSB of the LOW Nibble is set (1). This is to create an allowable range of values.
ex:
1111 1000 = 248
1111 0000 = 240 this case should not occur due to the high bit of the low nibble being set.
1111 1111 = 255
When the user reads the high nibble, the value can be any where within that range of decimal values and still be valid.
The Chicklet uses inverted logic. So when no buttons are pressed we will see the following binary value:
1111 1000 = 248(decimal)
When the device is disconnected we will see 126-128. Or:
0111 1110 = 126
0111 1111 = 127
1000 0000 = 128
These conditions cannot occur during game play. You can validate this through dash board. But if the Chicklet is calibrated properly this condition should not happen. The closest normal value we have observed is:
0111 1010 = 122
If you check for the above values (126-128) and they are true then the device is not connected. Try it out and let me know how well it works.
Mike Copioli
Unread 09-02-2007, 12:36
heydowns's Avatar
AKA: Jeff Downs
Mike,
You're right, that does make detection a bit more plausible.
The description was a little confusing at first, but makes more sense after re-reading.
Not sure if we'll have a chance to try this before ship, but we'll revisit after competition season; we've moved all functionality off the analog-in-digital space (we didn't need the extra buttons after doing a recalibration/reconfiguration).
Maybe someone else using this can post results.
Either way, it'd be nice to see this information (the summary of it, anyway) in a future rev of the user's manual.
Thanks for looking into this and sharing the details!
Unread 13-02-2007, 08:30
Mike,
We have tested the code on our robot and it works great. It would be a good idea to make the ranges defines and adjust them based on the specific Chicklet you are using. Also you must ensure that the Chicklet is calibrated and verify the outputs with dashboard to ensure you are not excluding a valid state.
Mike Copioli
Our Camera doesn't Detect magical hands Programming 3 27-01-2007 13:45
Reliable 2006 Camera Settings? Travis Hoffman Programming 5 17-04-2006 00:07
pic: Another one from way, WAY up CD47-Bot Extra Discussion 18 01-05-2004 02:31
IR senors detect pulses for 360 degrees Chaychay Technical Discussion 6 15-02-2004 15:06
Cheap, reliable hosting... Brandon Martus Website Design/Showcase 40 06-02-2003 08:55
