Go to Post I don't think that FIRST is going to get better with a top down solution alone, it is going to take a grass roots effort to strengthen teams. That starts by teams getting off their "islands", self imposed or otherwise. - Fe_Will [more]
Unread 07-02-2007, 13:45
jhallel jhallel is offline
FRC #1943
jhallel is an unknown quantity at this point
Microswitches
Hello,
We would like to ask you if we can use microswitches other than the ones that were supplied in the kit?
Thanks in advance,
Team 1943
Unread 07-02-2007, 14:11
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Microswitches
Yes. Just be sure to account for them in the BOM.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 07-02-2007, 14:20
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Microswitches
jhallel,
It is understood that switches of any kind can be used on the robot as long as they are acceptable through the flowchart in the robot section of the manual. Additionally,
<R72> All outputs from the sensors and additional electronics circuits used on the ROBOT must be
connected directly to other custom circuits or the analog or digital I/O on the Robot
Controller. It is acceptable to wire switches used as sensors in series or parallel with each
other.
Additionally both the RC Ref Guide and the Tips and Guidelines documents have discussions, hints and wiring guides for sensor inputs.
Please be sure that all connections made to switches be insulated and the switches wired in accordance with the above rule. If you have something unusual you wish to use, it is wise to ask the question of the Q&A.
Al
WB9UVJ
www.wildstang.org
________________________
microswitches and other sensor question chippermonky Electrical 3 08-02-2005 09:30
microswitches and other sensor question chippermonky Technical Discussion 3 08-02-2005 09:30
