Go to Post you know you are addicted to first when u crave sprockets for breakfast! - Jones571 [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 07-02-2007, 13:59
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Controlling motor speed
I would like to control the speed of motors so that my arm motors spin slowly, ie when I use my joystick to control my arm and push it full throttle, it would return a quarter throttle response. If you could step by step instruct in easycpro, I am a newbie rookie.
Unread 07-02-2007, 14:09
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Controlling motor speed
I can't help you with easyC but can explain the basics...
A PWM is defined to be:
255 - Full Forward
127 - Stop
0 - Full Reverse
Let's assume that your PWM is #1 and you are using the Y axis of the Joystick installed into Port 1 to control it. Your C code would look like this:
pwm01 = (unsigned char) ((((int) p1_y - 127) / 4) + 127);
(int) and (unsigned char) are compiler directives called a cast. (int) tells the compiler to transform the unsigned char, p1_y, to a signed integer. (unsigned char) transforms it back.
Note that there are many ways to skin a cat, all of which are intensely undesirable to the cat...
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 07-02-2007, 22:25
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
You should use the online window to determine the speed you want your arm to move at and then using a formula like Mike posted make that your maximum.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 07-02-2007, 23:01
FRC #2027
I understand the formula however I do not have anything in my c window that resembles his format "pwm01 = (unsigned char) ((((int) p1_y - 127) / 4) + 127); otherwise I would replace my code with his. What steps in easycpro would I use to generate code in that format?http://www.chiefdelphi.com/forums/im...es/redface.gif
Unread 08-02-2007, 07:04
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
Here is the easiest way to do this in easyC.
Code:
      int Arm_Joystick;
      unsigned char Arm_Output;
      while ( 1 )
            Arm_Joystick = GetOIAInput ( 2 , 2 ) ; // Analog OI Input Block
            Arm_Output = ((( Arm_Joystick - 127 ) / 4) + 127 ) ; // User Code Block
            SetPWM ( 4 , Arm_Output ) ; // PWM Control Block
Here is a more advanced way to do this in easyC Pro
Code:
while (1)
         SetPWM ( 5 , ((( GetOIAInput(2,2) - 127) / 4) +127 ) ) ;
Oh, and when you put a smiley in your post all you have to do is click on the smile you want once and the forum software
automagicly loads the image.
Unread 08-02-2007, 11:01
FRC #2027
Thanks
With a little tweaking your more advanced code worked perfectly!
Unread 08-02-2007, 13:54
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
Variables are overrated
Unread 11-02-2009, 18:23
Drake Hunter's Avatar
Drake Hunter Drake Hunter is offline
Fighting Rednecks
FRC #2883 (F.R.E.D)
Drake Hunter is an unknown quantity at this point
Can anyone help me in labview?
Unread 12-02-2009, 21:29
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
This isnt the proper area to ask a labview question. I would suggest going under Programming > Labview
Unread 16-02-2009, 22:50
Fighting Rednecks
FRC #2883 (F.R.E.D)
no kidding....but i needed help so i figured i would ask
Motor speed HellBoy Programming 2 05-02-2007 10:41
Multi-Speed motor Questions Burg Robotics Education and Curriculum 2 23-12-2004 15:54
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
Drill Motor Speed Difference Mark Jones Motors 2 14-02-2003 15:23
Drill motor true speed? archiver 2001 0 23-06-2002 23:58
