Go to Post I think this can be cleared up easily...one of the New Hampshire teams needs to go dumpster diving at FIRST HQ and look for an invoice. - Vaillancourt88 [more]
Unread 07-02-2007, 19:24
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
Rookie Year: 2007
bronxbomber92 is an unknown quantity at this point
On-Board Battery Charger
In section 8, rule 54 (I believe 54, not 100% sure, but it is in the fifties) it states that FIRST will be posting a "guideline" to build a Charger for the camer'a backup battery, that will charger through the main battery. I cannot find this document posted anywhere. Does any one know where to find it?
Thanks,
Jedd
Unread 07-02-2007, 19:38
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: On-Board Battery Charger
I believe the document you seek is located here:
http://ifirobotics.com/docs/first-backup-charger.pdf
I found it on Innovation First's website, ifirobotics.com, and it was under Robot Controller.
JBot
Aren't signatures a bit outdated?
Unread 07-02-2007, 19:59
Rookie Year: 2007
Thanks a lot! I believe this is it
Unread 07-02-2007, 23:32
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Bomber,
Please do a search on this subject. You will find a number of threads dedicated to this subject.
<R56> requires that you use the IFI design if you charge the backup battery on the robot. While the IFI design states that IFI does not support this design.
Many degreed engineers have reviewed this circuit and quite a few of us have reservations about it.
Unless you know what you are doing, I would suggest sticking to off-robot charging.
JMHO.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 08-02-2007, 08:31
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Mike,
The backup battery charger schematic was changed and updated on Jan. 25th. I believe this new revision corrects the problems that existed with the original charging scheme. You may want to take a look and see if the new revision makes you electrical guys happy.
BEN
Unread 08-02-2007, 09:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Ben,
The answer on that would still be 'NO". There is a long thread about this with some great discussion and a better design.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-02-2007, 11:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The revised circuit does make a lot more sense than the original one, but it still has the big problem of letting the backup battery power things connected to the main 12v supply.
I wonder if it would be legal to power the charger from a Spike output.
Battery charger model# ? computhief263 Programming 3 22-03-2004 13:21
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery Charger Circut PyroPhin Electrical 1 30-01-2003 13:49
battery charger archiver 2001 3 23-06-2002 23:20
Battery Charger jgrater Kit & Additional Hardware 1 12-04-2002 14:14
