Go to Post Gracious professionalism is a two-way street. - Bharat Nain [more]
Unread 08-02-2007, 12:44
Calvin_1631's Avatar
Calvin_1631 Calvin_1631 is offline
AKA: Calvin
FRC #1631 (Cybernetic Cougars)
Team Role: Electrical
Calvin_1631 is an unknown quantity at this point
Motor problems
Hello,
We have an arm that weighs about 6 pounds that is mounted on two posts. It rotates on a rod that is about 4" from the end of the robot. That arm has a gear attached to it and a chain leading to a window motor. However once the arm gets past center it can't control the arm, and thus the arm comes "crashing," in a sense, down. The motor has a worm gear, yet it can't stop the motor momentum. Is there some motor that we can get that has a stronger worm gear? I will get the motor name and number once we get to school later today. It is a motor from a few years ago, with an 11mm shaft that turns into a screw end, if that helps any veterans.
Annoying motor problems... jazzsaxman1988 Programming 8 03-02-2005 08:49
Drill Motor + Gearbox + Breaker Problems sear_yoda Electrical 28 03-03-2004 20:03
More drill motor problems, jeeze. blindguy Motors 4 12-02-2003 09:06
chapita motor problems lockportcew Motors 2 05-06-2002 11:16
Drill Motor Gearbox Problems... Jim Meyer OCCRA 1 16-10-2001 06:17
