Go to Post It's wonderful to think of how close together we all grow, win or lose. - Po-ser [more]
Unread 08-02-2007, 17:10
almsfan21 almsfan21 is offline
FRC #1804
almsfan21 is an unknown quantity at this point
Globe Motor Wiring
How is the globe motor supposed to be wired? We cannot find compatible "clips" that match the motor. Do we need to buy some, or were they supposed to be in the KOP?
Unread 08-02-2007, 17:21
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Globe Motor Wiring
You can strip the wires and add your own connectors (see <R38>). A good crimp/solder joint is recommended. Remember to insulate whatever remains.
Unread 08-02-2007, 17:37
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
on a similar note, is the globe motor allowed to be run off of a spike this year?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 08-02-2007, 17:51
Rookie Year: 1999
Yes, it's allowed to be used with a Spike. Spikes require that there be a 20 A breaker in the circuit, and 20 A breakers require that the wire be 18 AWG or larger.
The only motors that you need to run from Victors are the Johnson F-P (9012) and both flavours of CIM.
globe motor lil_longo Motors 1 18-02-2006 12:27
globe motor chrisinmd Motors 9 11-02-2006 10:58
Globe Motor Team168 Programming 3 16-02-2003 11:50
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
