Go to Post Measure it with a micrometer, mark it with chalk, and cut it with an axe. This is not an exact science. - Jim Meyer [more]
Unread 08-02-2007, 17:26
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
wierd compiling error
ok heres whats happening to my code.
I have two encoders, an internal timer and modified Kevin watson's camera code. and when I try to compile this code it goes through the motions and when it goes to compile a file that we are using to hook into the user_routines / user_routines_fast it pops up with an error saying that "This application has requested the Runtime to terminate it in an unusual way." it then says that the build failed.
does any one know anything about this type of error?
and where I can even start to fix this problem??
Unread 08-02-2007, 21:32
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Re: wierd compiling error
First off, what do you mean by this? Is it a file that you #include in user_routines.c? Or something more unconventional?
Second, is this an error that MPLAB pops up, or is it written by the compiler/linker to this console? If you can't tell, paste the console output (the place it usually says 'BUILD SUCCEEDED' or something like that) here on CD.
Good luck,
Robinson
huh, anyone ever get this compiling error? fallen751 Programming 2 24-01-2007 23:14
Error when compiling paulcd2000 Programming 2 21-01-2007 14:05
Very wierd compiling problem! Max Brin Programming 6 08-02-2006 15:43
Error in Compiling the Camera Code (B&W Version) VetteSlick Programming 7 20-01-2006 20:50
Wierd error (With edu bot ... Salik Syed Programming 4 09-03-2004 21:34
