Go to Post "Congratulations to our FIRST team coming back from the championships in St. Louis." (We all applaud) "Remember, if you're not FIRST, you're last!" - Our pilot on the second plane back home. - demosthenes2k8 [more]
Unread 09-02-2007, 08:25
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Rookie Year: 2007
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
How do you get servo numbers into Angle Degrees
I was woundering on how do you get the tilt angle that the servo is at into degrees for an angle. Any programing help would be nice or give me a way to figure that out.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 09-02-2007, 09:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: How do you get servo numbers into Angle Degrees
Hi and welcome to Chief Delphi! Glad to see another fellow Minnesotan around.
Here at CD there is a forum specifically dedicated to the CMUCam which can be found here.
After browsing through it, it appears this thread is very similar to what you are asking.
We also have a search function here that can be very helpful. It helps you find answers faster and helps all the excellent helpful people here have less threads to wade through.
If none of that answered your question, feel free to post again in this thread and let us know what is still giving you trouble.
-Kevin
Unread 13-02-2007, 01:06
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
For if you have not figured it out yet.
The camera tracking menu which has a submenu for driving the pan/tilt servos interactively. Use a proctractor to measure the values.
Get the pwm values for zero pan / zero tilt since this is probably different from the default values stored in tracking.h and stored in the camera eeprom. We then moved one servo at a time 100 pwm steps off center either way and measured the angles.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 18-02-2007, 12:16
No Stolte No
AKA: Chris
Rookie Year: 2007
Thanks that helps a little but we indead up not doing autonomous Ran out of time. We had no robot to work with the autonomous.
Servo Values to Degrees... How? mogunus Programming 16 11-04-2007 02:03
Servo Offset -> Angle conversion bush Programming 11 30-01-2006 13:34
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
How high will the numbers go? you think we'll hit team 911 archiver 2001 10 24-06-2002 03:42
How much time do you put into building your robot Wayne Doenges General Forum 16 29-01-2002 19:30
