Go to Post Life is unfair. Learn to deal with it or be unhappy. - Joe Johnson [more]
Unread 09-02-2007, 11:05
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
CHICKLET PROBLEM!!
Ok, so we are trying to callibrate our chicklet to run with a Xbox 360 controller. We enter it into callibration mode and pick mode two. It blinks 12 times telling us we have 12 inputs to use. So we start input buttons, and at the 7 button it blinks red. green,red telling us we are done. But we only got 7 inputs in?? Also when we hook up the usb chicklet to the OI and plug the RC into it for testing. The printf( reads that two buttons are always on and evenutally it gives us a code error and the entire thing freezes. Can anyone help? I would really like to be able to use this thing lol
Unread 10-02-2007, 09:46
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: CHICKLET PROBLEM!!
Ok, In mode 2 the LED should only blink green 4 times not 12. Ensure that you are using a Microsoft brand X-box 360 controller. You do not need to use printfs to verify that the Chicklets data is what you expect. You should be using the dashboard for this. A code error on the R/C could occur for many reasons but can only be caused by your code and not the Chicklet. Your code may be in an infinate loop due to some event that has occured or you may have the wrong processor selected in mplab. First, I would verify that the Chicklet has been calibrated properly using dash board. Once that has been done, find the cause of your code error.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Chicklet Help haywirerobotics Programming 5 06-02-2007 08:12
USB Chicklet SleeveofWizard Control System 11 28-01-2007 22:45
chicklet carbuff Control System 1 27-01-2007 13:51
Fried chicklet karin l. Control System 5 24-01-2007 00:07
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
