Go to Post The whole idea of a robot competition is geared around spectators. Take that away and you have a science fair. - Chris is me [more]
Unread 09-02-2007, 17:47
whlspacedude's Avatar
whlspacedude whlspacedude is offline
AKA: Will
FRC #1529 (Cyber Cards)
whlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nice
Send a message via AIM to whlspacedude Send a message via MSN to whlspacedude Send a message via Yahoo to whlspacedude
WE NEED PGRM HELP
We need to be able to run a function when we push a button on the controller (trigger, thumb etc.). problem being that we have no clue how to run easy c. thanks!
Some people are like slinkies they are only good for 1 thing... pushing them down flights of stairs
1529 mph = 4 109 952 furlongs per fortnight
Unread 09-02-2007, 18:06
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: WE NEED PGRM HELP
What you need to do is go into the Operator control function, and from the program flow tab on the left side drag a while loop into the function and put a 1 in the box that comes up this will cause the program to loop until the bot is turned off.
Then drag an if block from the same place and drag it inside the while loop, in the box that comes up type
Code:
GetOIDInput([the port you want], [the button number]) == 1
To see what each button number is from the input tab drag OI Digital Input block and the box that comes up will show you what each one is.
What this does is looks if the button is pressed if it is it returns a 1 if not it returns a 0, and the == 1 part looks to see if it is a 1, if it is the code in the if statement will execute otherwise it will skip it, so put whatever you want to have happen when that button is pressed in the if statement.
Here is an example of what the if statement would look like. This one checks if the second joystick trigger is pressed and if it is allows the joysticks to drive the motors.
Code:
        //Check if user drive
        if(GetOIDInput(2, 1)==1)
            Joystick_Drive();
I'm done rambling now
Hope this helps
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 15-02-2007, 14:35
AKA: Will
Thanks that really helped alot!!!!!!!!!!!!!!!
whlspacedude
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
HELP!! i need help starting a new team!! shyra1353 Starting New Teams 18 07-10-2003 17:55
