Go to Post I firmly believe that it's within your power to aspire instead of lament. - Alan Anderson [more]
Unread 10-02-2007, 01:39
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Chain Covers
Say I have a part that moves with chains, not the drive system. Say it's a bar that swings around by a chain system, do those chains and sprockets need to be covered up(do the rules make you)? For example with lexan?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 10-02-2007, 02:02
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Re: Chain Covers
Last year I thought that this would be something that the judges would really look out for, seeing all of these safety regulations that we have to obey. But at the competitions, I really didn't see many teams with chain guards around pinch points. We still did our best to make it impossible to reach our chains without unbolting things first, but I don't think it was really looked at during inspection.
I would say try and make chain guards anyway. If you are having thoughts about it seriously injurying someone, then it would probably be wise to make it safe even if you can pass inspection without doing so.
Unread 10-02-2007, 10:56
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Re: Chain Covers
Where are the rules on this?
Callsign: N6ARA
Unread 10-02-2007, 11:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Chain Covers
<R04> should cover it, consider that where a chain meets a sprocket is a serious pinch point hazzard
And I think that the reply that Steve (s_forbes) gave above might be a bit misleading, as the robot he has experience with was actually pretty well covered up. The one the team is building this year has a big sprocket and chain out in the open, and will definitely need chain guards.
Unread 11-02-2007, 00:45
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Chain Covers
If the chain/sprocket pinch point could come in contact with other robots, and possibly game pieces, it might need to be covered, however, I've seen a ton of robots with similar designs that did not have them covered.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 11-02-2007, 02:09
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Chain Covers
Chains are so common that I think they get ignored. Particularly in the drivetrain it would be a huge pain to try and cover up every corner the chain makes. Generally they are already in areas that while perhaps a limb might be able to reach, certainly would be reaching anywhere near when a robot was being turned on or running.
Team Website
Unread 12-02-2007, 10:55
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Chain Covers
What inspectors look for also includes areas that may pinch or injure field volunteers should they touch your robot while it is on the field. i.e. A ref is trying to determine the position of your robot and inadvertantly puts his hand near a mechanism. Another person moves your robot or manipulator. Will the action cause someone to be injured? If the answer is yes (or if the inspector thinks it might) a cover is then appropriate.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-02-2007, 11:01
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Chain Covers
mama always said better safe than sorry
it may be a pain, but if someone doesnt get hurt cause of it, than it was worth it. it also makes your robot look more elegant, like you went that extra step for safety.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 12-02-2007, 21:21
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Re: Chain Covers
Is this legal?
http://aksimhal.googlepages.com/chain is the link of a picture of our chain of our arm.
Thanks,
Unread 12-02-2007, 22:46
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: Chain Covers
The problem is ussualy not the long runs of chain but where it meets a sprocket becuase a limb could get caught between the chain and a tooth and get seriously injured. I would look closely at where your chain hits a sproket and less at the long run between, so yes, that is legal.
I know that on my bot, i'm going to tyr to cover the pinch pounts cause I have pinched my finger when I was moving the chain around its look and it hurt (not badly). I could only think what might happen if the motors had been running it.
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
What to do with those NEVER AGAIN NEEDED beacon covers?! skrussel General Forum 14 02-02-2004 21:51
American and Japanese Book Covers LBK Rules Chit-Chat 1 09-01-2004 15:53
Punk covers - awesome or ruining good music? DanL Chit-Chat 19 12-05-2002 14:39
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
