Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 10-02-2007, 12:58
JimHull's Avatar
JimHull JimHull is offline
FRC #1891
JimHull is an unknown quantity at this point
HS-322D servo programming question
I am trying to use an HS-322D servo. I cannot seem to get it to respond to my commands.
It is connected to pwm05. Do I not just code pwm05=x;? "x" being 0 to 254? Am I missing something?
Unread 10-02-2007, 13:01
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: HS-322D servo programming question
That would be correct on the programming terms. . . .
Couple things it could be. . .
  • Code is in an if statement and the statement is never true
  • Backup battery not attached (dead) the servos are powered by the backup battery
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 10-02-2007, 13:02
FlyingDutchman FlyingDutchman is offline
FRC #1566
FlyingDutchman will become famous soon enoughFlyingDutchman will become famous soon enough
hay sweet we're in the same state!!! i personaly dont know so ill go get the programing captan.... Yeah, uh, I think that's all you have to do. Make sure nothing else would be controlling pwm05. Good Luck!
Unread 10-02-2007, 13:04
JimHull's Avatar
FRC #1891
I did have a dead backup battery plus a bad wiring harness. Got that all taken care of. Have 7.8VDC on the bus. The servo twitches when I first power it up but then when it executes my code it does nothing. It is just straight code. No if statements.
Unread 10-02-2007, 13:09
FRC #1566
just the normal oner of the acount... like I said before I know nothing about programing so try this is the plug all the way in and is it in the right spot
Unread 10-02-2007, 13:11
Eclipse's Avatar
Eclipse Eclipse is offline
AKA: Sensei Hanzo
FRC #1250 (Gatro-Bots)
Eclipse is an unknown quantity at this point
Well, if you're expecting it to be constantly moving, that might be the problem. Pardon me if you already knew this, but servos move to positions as opposed to spinning around at different speeds. Commanding it to 0 would set it to one end of its travel and 254 would be the opposite end.
xXx.S3nS31-h4nz0.xXx
Unread 10-02-2007, 13:16
JimHull's Avatar
FRC #1891
That is exactly what I want it to do. It is has 90degrees of motion and I want it to move over its entire range. So at initialization I would move it to the 0 position then when I activate it I want it to rotate the full 90degrees to the other end of its travel.
Unread 10-02-2007, 13:19
Eclipse's Avatar
AKA: Sensei Hanzo
What exactly are you doing in your code? Are you setting it to 0 in User_Initialization and then setting it to 254 in the main code?
Unread 10-02-2007, 13:41
JimHull's Avatar
FRC #1891
Well pwm05 is set to 127 in the initialization part of the code (default). Then in my Default_routine() I have the following:
pwm05=0;
for(i=0;i<10000;i++); // quick and dirty delay
pwm05=254;
Unread 10-02-2007, 13:57
Eclipse's Avatar
AKA: Sensei Hanzo
Are you sure Default_Routine() is being called? I know that in Kevin's code, Default_Routine() is commented out due to it interfering with camera PWMs. Try checking that?
Unread 10-02-2007, 14:45
JimHull's Avatar
FRC #1891
Ok. First of all. I need more sleep.
Here is what happened. I was making changes to and downloading the wrong code. The rest of the team had created a new directory for a new version of code and had left the old source code open. I was in effect downloading the same hex code all this time. Unmodified hex code.
So. The solution is so freakin' simple.
pwm05=x; // set Servo to desired position.
Thanks for all the help guys and gals....
Unread 10-02-2007, 15:12
Eclipse's Avatar
AKA: Sensei Hanzo
Ha ha. Don't worry. I've had that problem too. XD;
Well, glad you figured it out. =)
Unread 10-02-2007, 15:14
JimHull's Avatar
FRC #1891
I hope my struggle will help others overcome any hurdles they encounter with the servos. There is very little information in the forums on the servos so I knew it had to be a very simple implimentation.
Question about CMUCAM servo output itsme Programming 9 13-01-2007 17:44
C programming question starchypizza Programming 2 18-11-2006 23:13
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
C Programming Question tophq Programming 7 16-02-2004 12:56
Programming question archiver 2001 6 23-06-2002 22:57
