Autonomous Two wheel problem???
So here's the problem:
We have 4-wheel / 4-CIM setup, each CIM running an independent speed controller. Normal drive code functions properly with the sticks, but when jump the ports on the OI to activate autonomous mode to track the light, only the back two wheels spin at all. Pulling up the dashboard viewer shows that all four CIMs are getting PWM values, yet the front two refuse to spin.... Thanks for your help... |
Re: Autonomous Two wheel problem???
If you look at the speed controllers during autonomous mode, do the lights for the inactive motors change the same as the active ones? If Dashboard shows that the PWM values are being sent, I'm inclined to think that it would be an electrical problem rather than programming.
Check your speed controller calibration.
We just use a PWM y-connector (the red/black/yellow included in KOP) to connect ONE PWM OUT channel to the pair of speed controllers for the left side motors, and a second PWM OUT channel the pair of controllers for the right side motors.
Of course the speed controller pairs should be identically calibrated ... |
| Autonomous problem | railerobotics | Programming | 7 | 07-02-2006 08:36 |
| One or Two Wheel Shooter | Nitroxextreme | Technical Discussion | 6 | 14-01-2006 01:10 |
| Problem using two transmitters | jamesgecko | FIRST Tech Challenge | 9 | 12-05-2005 09:30 |
| Autonomous Problem... | JoeFryman | Programming | 2 | 19-02-2005 14:56 |
| Autonomous problem. | Code\\Pilot | Programming | 8 | 10-02-2004 19:40 |
