Bumper Question - More like Pool Noodle
When making bumpers, are you allowed to segment the pool noodle that will go inside the bumpers? The way our robot and bumpers are made, it will require us to take out the pool noodle in order to attach/detach bumpers. If we cut the pool noodle, this won't require us to take out the entire pool noodle.
On that note, I also wanted to know if it is okay to tape the pool noodles, since I know there's a restriction on tape. (ie. Taping segments of pool noodle togther to make a long enough pool noodle.) |
Re: Bumper Question - More like Pool Noodle
According to rule <R37>: "STANDARD BUMPERS do not have to surround the entire perimiter of the ROBOT, and may be segmented"
We cut our noodles down to 27 inches last year for the front and back of our robot and never had any problems. |
Blue,
You may not tape the pool noodles or modify them in any way. The rule book robot section is very specific and there is additional discussion in the Tips and guidelines. There is also a nice discussion on how to use mounting hardware on these devices. Threaded rod, eye bolts and T-nuts all work for this application. See rule 37 in the robot section of the manual. Pay particular attention that only standard bumpers may be excluded from weight and size. "STANDARD BUMPERS have several advantages, such as being excluded from the calculation of the ROBOT weight and volume limitations specified in Rule <R07>." |
No tape (well, unless it's not self-adhesive). |
yes pool noodles are the stuff you use for the bumpers, id say just attatch it to another peice of metal or something that can be screwed and unscrewed in...
I was thinking about velcro-ing the pool noodles to the plywood...however, if you build them right, the fabric should hold them in place.
| bumper question | math4origami | Rules/Strategy | 4 | 16-01-2007 14:47 |
| Question about programing the bumper sensors | itsme | Programming | 9 | 10-12-2006 18:03 |
| noodle bumper | munch | General Forum | 2 | 09-02-2006 17:25 |
| A couple of noodle scratchers | Cheese Head | Programming | 11 | 07-12-2002 09:59 |
| here's another question, Do you like rap music? | mike pawlak | Chit-Chat | 49 | 08-05-2002 23:28 |
